Ir para o conteúdo principal
Huawei P10 Headphone Jack Replacement
O que você precisa
  1. Huawei P10 Headphone Jack Replacement, Back Cover: passo 1, imagem 1 %32 Huawei P10 Headphone Jack Replacement, Back Cover: passo 1, imagem 2 %32 Huawei P10 Headphone Jack Replacement, Back Cover: passo 1, imagem 3 %32
    • Switch off your phone.
    • Remove the two Pentalobe P2 screws at the bottom.
    • Remove the SIM card tray.
  2. Huawei P10 Headphone Jack Replacement: passo 2, imagem 1 %32 Huawei P10 Headphone Jack Replacement: passo 2, imagem 2 %32 Huawei P10 Headphone Jack Replacement: passo 2, imagem 3 %32
    • Insert a plastic opening tool between the display and the case starting at the bottom area of your phone.
    • Carefully pry the display with its parts out of the case.
    • Getting the prying tool in will require some effort, be careful not to slide the tool too much or you might slightly damage the housing.
    • After you pried out the bottom end, use the opening tool to open the clamps on both sides.
  3. Huawei P10 Headphone Jack Replacement: passo 3, imagem 1 %32 Huawei P10 Headphone Jack Replacement: passo 3, imagem 2 %32
    • Don't open the phone all the way, yet. The cable for the standby and volume buttons is still connected to the back cover.
    • Swing open the phone backwards.
    • Use a spudger to disconnect the power- and volume button flex cable.
  4. Huawei P10 Headphone Jack Replacement, Battery disconnect: passo 4, imagem 1 %32 Huawei P10 Headphone Jack Replacement, Battery disconnect: passo 4, imagem 2 %32 Huawei P10 Headphone Jack Replacement, Battery disconnect: passo 4, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the Phillips #00 screw.
    • Use tweezers to remove the metal plate.
    • Use a spudger to disconnect the battery flex cable.
  5. Huawei P10 Headphone Jack Replacement, Headphone Jack: passo 5, imagem 1 %32 Huawei P10 Headphone Jack Replacement, Headphone Jack: passo 5, imagem 2 %32
    Comprar
    • Remove the three Phillips #00 screws.
  6. Huawei P10 Headphone Jack Replacement: passo 6, imagem 1 %32 Huawei P10 Headphone Jack Replacement: passo 6, imagem 2 %32
    • Use the flat end of a spudger to disconnect the headphone jack.
    • Remove the headphone jack.
    • There is a small piece of adhesive underneath, so it might be a little bit sticky. You can use an iOpener to loosen the adhesive and make the removal easier.
    • When reassembling apply new adhesive where it's necessary.
Conclusão
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
Dominik Schnabelrauch
Membro desde: 11/23/16
210.056 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 141
Autoria de 17.895 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 2,928
