Ir para o conteúdo principal
Huawei Mate 9 Battery Replacement
O que você precisa
  1. Huawei Mate 9 Battery Replacement, Back Cover: passo 1, imagem 1 %32 Huawei Mate 9 Battery Replacement, Back Cover: passo 1, imagem 2 %32
    • First switch off your phone and remove the SIM card tray.
  2. Huawei Mate 9 Battery Replacement: passo 2, imagem 1 %32 Huawei Mate 9 Battery Replacement: passo 2, imagem 2 %32
    • Remove both screws on the bottom with a Torx T2 screwdriver.
    • Use a plastic opening tool to get between the display and the case. Open the smartphone by carefully prying out the display with all the parts out of the case.
    • Don't open the phone all the way, yet. The fingerprint sensor cable is still connected to the back cover.
  3. Huawei Mate 9 Battery Replacement: passo 3, imagem 1 %32 Huawei Mate 9 Battery Replacement: passo 3, imagem 2 %32
    • Swing open the phone to the right side.
    • Disconnect the fingerprint sensor cable with a spudger.
  4. Huawei Mate 9 Battery Replacement, Battery Disconnect: passo 4, imagem 1 %32
    • Carefully peel off the plastic sticker that holds both cables to the battery.
  5. Huawei Mate 9 Battery Replacement: passo 5, imagem 1 %32
    • Remove the water indicator sticker and the Phillips #00 screw beneath it, that holds the cable bracket in its place.
  6. Huawei Mate 9 Battery Replacement: passo 6, imagem 1 %32
    • Remove the cable bracket.
  7. Huawei Mate 9 Battery Replacement: passo 7, imagem 1 %32 Huawei Mate 9 Battery Replacement: passo 7, imagem 2 %32 Huawei Mate 9 Battery Replacement: passo 7, imagem 3 %32
    • Use a spudger to disconnect the interconnect, the battery and the display flex cable.
  8. Huawei Mate 9 Battery Replacement, Battery: passo 8, imagem 1 %32 Huawei Mate 9 Battery Replacement, Battery: passo 8, imagem 2 %32
    • Peel out the adhesive strip which is placed beneath the battery by steadily pulling at the tab in a flat angle.
    • If the adhesive strip breaks, grab and twist it around tweezer tips a couple of times and then continue.
  9. Huawei Mate 9 Battery Replacement: passo 9, imagem 1 %32 Huawei Mate 9 Battery Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada neste passo:
    Tesa 61395 Tape
    $5.99
    Vorsicht bei diesem Schritt!
    Der Akku ist in der unteren Hälfte mit sehr gut klebendem Tape gesichert! Ein massives Hebeln zerstört den Akku (Akku knickt und Zellen bekommen einen Kurzschluss)!
    Hebelt ihn wie auf dem Bild, oben etwas hoch damit ihr mit einer alten EC oder Kreditkarte o.ä. unter den Akku kommt und damit das Tape langsam wegdrücken könnt.
    Tobias Hannemann - Responder
    Der Klebstoff an der Unterseite des Akkus hielt diesen bei meinem Gerät ziemlich fest und ließ sich trotz zweimaligem langen Auflegen des 30 Sekunden in der Mikrowelle erwärmten Opening-Pick-Gel-Kissens nur mühevoll lösen. Ohne Gefahr zu laufen, dabei den Chassis-Rahmen mit dem darunter befindlichen Display zu verbiegen und dieses zu beschädigen, half mir die Kante des Spudgers, den Akku Millimeter um Millimeter vom Klebstoff allmählich zu lösen. Ein stabiler dünner Plastikspachtel könnte dabei besonders hilfreich sein. Das alte Akku-Kissen riss beim lösen aus dem Chassis-Rahmen und entzündetes Gas des Lithium-Ionen-Gemisches entwich unter leichtem Funkensprühen. Es ist also Vorsicht geboten sowohl beim Entfernen, bei der späteren Aufbewahrung und der Entsorgen des alten, in meinem Falle beschädigten Akkus.
    Angesichts dieses Umstandes und dass es nicht einfach war, das Gerät zu öffnen (Schritt 2), stufe ich den gesamten Vorgang des Akkutausches eher als moderat bis schwierig ein!
    Nemo Outis - Responder
Conclusão
To reassemble your device, follow these instructions in reverse order. When reassembling your phone apply new adhesive where it is necessary.
28 outras pessoas executaram este guia.
Dominik Schnabelrauch
Membro desde: 11/23/16
230.309 Reputação
Autoria de 682 guias
Equipe
iFixit Membro de iFixit
Staff
118 Membros
Autoria de 19.537 guias
7 comentários
Danke für die detaillierte ANleitung, konnte meinen Akku wechseln und nun ist mein Handy wieder wie neu.
francisco.perez - Responder
it’s almost impossible to remove the battery without damaging it!
My advice to you is to buy the LCD screen with the battery included.
madani_salar - Responder
Habe es leider nicht hinbekommen - beim Versuch den Klebestreifen mit der Pinzette zu greifen hat mein Akku Feuer gefangen…
thej95 - Responder
Das hat sehr gut geklappt mit der Anleitung. Danke dafür, super happy.
Im Basic Rep Set fehlte leider einer der notwendigen Torx Schraubendreher.
Andreas Rapp - Responder
War erfolgreich die OP. Die Batterie war allerdings festgeklebt wie verrückt und nur sehr schwer raus zu bekommen. Musste ein flaches Messer zuhilfe nehmen, anders gings nicht. Ich hatte sie vor der Rep. glücklicherweise auf 10% entladen, damit nicht so viel passieren kann, wenn sie beim entfernen hochgeht ;-) Ist allerdings nichts passiert. Die Ladebuchse hab ich bei der Gelegenheit auch gleich getauscht, die hatte auch oft keinen richtigen Steckerkontakt mehr. Alles in Allem ca 1,5 Std. Zeitbedarf. Danke für die Anleitung.
Michael Megerle - Responder
Die Reparatur hat geklappt. Allerdings war es sehr schwer den alten Akku herauszubekommen. Der war mit zwei Klebestreifen fast vollflächig verklebt. Da könnte man die Anleitung vielleicht etwas schärfen.
Michael - Responder
Super Anleitung! Den festgeklebten Akku zu entfernen war allerdings sehr schwer. Ich konnte das weiße Klebeband nicht rausziehen.
Ein Tipp: Ich haben den Akku so weit angehoben, bis das Klebeband sichtbar wurde und dann einen schmalen Papierstreifen in Nitroverdünnung getaucht und die Klebestelle mit der Nitroverdünnung benetzt, das löst den Kleber. Man kann dann Stück für Stück den Akku immer weiter anheben, bis er ganz gelöst ist.
Bernd Reichert - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 51
Últimos 30 dias: 265
Ao todo: 26,952
