Introdução
Use this guide to replace the charging port in your Huawei Mate 10 Pro smartphone.
O que você precisa
Switch off your phone.
Prepare an iOpener and apply it to the back of the phone for about two minutes to loosen the adhesive beneath the back cover.
Remove the twelve Phillips #00 screws.
Carefully remove the shields on top of the motherboard and the charging board.
Use a spudger to disconnect the charging port flex cable from the motherboard and from the daughterboard.
18 outras pessoas executaram este guia.
2 comentários
Great tutorial! It has been a month without being able to charge my phone, and now it charges 2x as fast with my repair.
I recommend testing the USB C flex cable assembly before you reassemble the phone. As soon as it’s connected to the upper connector and the battery is plugged in the phone should be charging. Mine was broken from the factory but I went to a great local repair shop and got a new one, the guy said 1 out of 15 is broken from the factory. Great tutorial, successful repair.
