Ir para o conteúdo principal
How to remove pilling
O que você precisa
    1. How to remove pilling, Material preparation: passo 1, imagem 1 %32 How to remove pilling, Material preparation: passo 1, imagem 2 %32 How to remove pilling, Material preparation: passo 1, imagem 3 %32
      • Lay out the garment on a clean surface. Prepare the pilling shaver.
      Pergunte ao FixBot
      Comentar
    2. How to remove pilling, Remove the pilling: passo 2, imagem 1 %32 How to remove pilling, Remove the pilling: passo 2, imagem 2 %32 How to remove pilling, Remove the pilling: passo 2, imagem 3 %32
      • Smooth the garment to make sure it is flat before starting.
      • Make little circles with light pressure on the damaged fabric. The pilling will be cut away by the shaver.
      Pergunte ao FixBot
      Comentar
    3. How to remove pilling, Finished and ready!: passo 3, imagem 1 %32 How to remove pilling, Finished and ready!: passo 3, imagem 2 %32 How to remove pilling, Finished and ready!: passo 3, imagem 3 %32
      • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
      • Be sure to clean the lint from inside your shaver after use.
      Pergunte ao FixBot
      Comentar
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Uma outra pessoa concluiu este guia.
Ben Blischke
Membro desde: 07/19/23
10.548 Reputação
Autoria de 68 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
25 Membros
Autoria de 172 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 32
Ao todo: 745
