Ir para o conteúdo principal
How to remove and clean the buttons
O que você precisa
    1. How to remove and clean the buttons, How to remove and clean the buttons: passo 1, imagem 1 %32
      • First, we need to get inside the camera. Refer to the lens cleaning guide for steps on how to remove the front panel.
      Pergunte ao FixBot
      Comentar
    2. How to remove and clean the buttons: passo 2, imagem 1 %32
      • Once you have the front panel off, you are one step closer to accessing the keys. From here, you will need to remove the upper panel which will release the keys. Unscrew the screw and remove the small metal plate which holds the keys.
      Pergunte ao FixBot
      Comentar
    3. How to remove and clean the buttons: passo 3, imagem 1 %32 How to remove and clean the buttons: passo 3, imagem 2 %32
      • Remove the keys and clean using solution and a soft cloth. If the keys are damaged, you will need to replace them. You can purchase parts for your camera on Olympus's website.
      Pergunte ao FixBot
      Comentar
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 30
Ao todo: 975
