Ir para o conteúdo principal
How to refill a Zippo Lighter
O que você precisa
  1. How to refill a Zippo Lighter, How to refill a Zippo Lighter: passo 1, imagem 1 %32
    • Purchase lighter fluid – any type but do not use lighter fluid intended for barbecuing.
  2. How to refill a Zippo Lighter: passo 2, imagem 1 %32 How to refill a Zippo Lighter: passo 2, imagem 2 %32
    • Open the lid of the Zippo and extract the insert – firmly grip either side of the flint wheel with 2 fingers. Hold the bottom of the Zippo lighter with your other hand and pull up on the metal to free the insert of the lighter from its case.
  3. How to refill a Zippo Lighter: passo 3, imagem 1 %32
    • Set aside the metal casing.
  4. How to refill a Zippo Lighter: passo 4, imagem 1 %32
    • Turn the insert upside down – there should be a felt bottom that reads “Lift to fuel.”
  5. How to refill a Zippo Lighter: passo 5, imagem 1 %32
    • Unravel the paperclip. Lodge one end of the paper clip into the tiny hole and lift up the felt backing.
  6. How to refill a Zippo Lighter: passo 6, imagem 1 %32
    • Squeeze the lighter fluid can once into the loose cotton.
    • If your lighter fluid canister is large, you may want to transfer the fluid to a smaller bottle to prevent spillage.
  7. How to refill a Zippo Lighter: passo 7, imagem 1 %32
    • Wait 5 seconds, then squeeze the canister twice more into the cotton.
  8. How to refill a Zippo Lighter: passo 8, imagem 1 %32
    • Close the felt protector.
  9. How to refill a Zippo Lighter: passo 9, imagem 1 %32
    • Place the metal box back into the case.
  10. How to refill a Zippo Lighter: passo 10, imagem 1 %32
    • Let the Zippo sit and absorb the fluid for 1-2 minutes.
    • While waiting, wash your hands.
    • Done! Light the Zippo.
Linha de Chegada
25 outras pessoas executaram este guia.
Danielle Tran
Membro desde: 02/24/15
709 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-4, Green Winter 2015 Membro de Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Membros
Autoria de 15 guias
4Comentários do guia
I do have money to buy fluid could i put fluid from another lighter in it
Trinity Bullock - Responder
Howdy Trinity - it’s possible, but unlikely, that would work.
Zippo uses a white gas/naphtha type fuel. BIC, and most other encased plastic lighters, use butane type fuel.
Butane has to stay in a tightly sealed container or it will evaporate within a few minutes. Zippo lighters do not have this tight of a seal (even when upgraded with rubber or silicone gaskets).
If you have another Zippo lighter with the correct fluid in it I would recommend transferring the insert. This is easier than attempting to transfer the fluid itself as that is a complicated process resulting in losing a lot of the fluid anyway.
It’s possible to use non-branded forms of white gas/naphtha fluid in a lighter but I can’t recommend using anything other than “lighter fluid”. Other naphtha type fuels have application specific additives and may be extremely toxic.
PLEASE NOTE: some fluids marked as “white gas” are actually additive-free gasoline. This is highly explosive and therefore extremely dangerous to use as a lighter fluid.
Bird -
I always check the flint is still striking a spark before refilling as this is much less messy when the lighter is empty rather than full.
If there is no spark when triggered then the flint probably needs renewing, if there is spark and no ignition then refill,
Richard Morgan - Responder
You can also use old bic lighters for the flint, the life of the fluid ends far passed the life of the flint.
Phillip kalanick - Responder
Comentar
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 76
Últimos 30 dias: 243
Ao todo: 156,671
