Introdução
Squeaky trucks are an audibly annoying problem that can be easily remedied by simple application of household soap to the pivot cup of a set of skateboard trucks.
In this guide we will learn how to take off the hanger of the trucks by removing the nut, washer, and bushing spacer before it. Next, we will apply a certain amount of soap to the pivot cup to eliminate squeaking. Finally, we will reassemble the trucks and tune them to preference for a smooth and squeak-free riding experience.
O que você precisa
Begin by determining which of your trucks are making squeaky sounds when you turn
After you have added on the washer, screw on the kingpin nut and tighten to preference. The tighter the nut the stiffer the turning capability, so this is personal preference. Usually I find that screwing it on until 1 or 2 threads of the kingpin bolt are visible above the nut is sufficient.
If you find that you have put too much soap in the bearings and the board is no longer stable when standing on it, you can clean out the pivot cup by following the above instructions to remove the hardware to get to the pivot cup and cleaning it out with a paper towel or other material.
6 outras pessoas executaram este guia.
