Ir para o conteúdo principal
How to fix alignment on an E-TKT Label Printer
O que você precisa
  1. How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: passo 1, imagem 1 %32 How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: passo 1, imagem 2 %32
    • Reboot the device.
    • After the splash screen the machine will home by rotating until the magnet meets the hall sensor.
    • Check the letter J position in the top window: If the letter is visually centered (second image), then you can skip ahead to to Step 3.
  2. How to fix alignment on an E-TKT Label Printer, Rough adjustment: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Turn off the device to avoid short circuiting the leads of the hall sensor.
    • Use blunt tweezers to finely adjust the hall sensor position along the tangential (cyan) axis as shown in the image:
    • If J is too much to the right, push the hall sensor toward the centre of the device (yellow arrow).
    • If J is too much to the left, pull the hall sensor towards yourself (magenta arrow).
    • Make sure to keep the same distance on the transversal (red) axis.
  3. How to fix alignment on an E-TKT Label Printer, Fine tuning: passo 3, imagem 1 %32 How to fix alignment on an E-TKT Label Printer, Fine tuning: passo 3, imagem 2 %32
    • Enter the web interface and click on SETUP.
    • Now press the TEST-button to the right side of ALIGN.
    • The machine will now slowly and lightly press the carousel letter, as shown in the second image.
    • Adjust the ALIGN-value until the press is fully centered on the character being pressed.
    • The align value ranges from 1 to 9, with 5 being the default (middle) value.
Conclusão
Happy printing!
Sebastian
Membro desde: 08/19/18
31.061 Reputação
Autoria de 71 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 243
