Ir para o conteúdo principal
How to fix alignment on an E-TKT Label Printer
Sebastian
Sebastian e um outro colaborador
Última atualização em May 23, 2023
1 - 5 minutos
Muito fácil
Guia colaborativo
Introdução
Ir para o passo 1
The E-TKT printer uses a daisy wheel mechanism to print labels, and if this wheel is misaligned, it can cause a range of printing problems. The printer finds its homing position through a Hall effect sensor, which can sometimes get bent out of position if the printer is handled roughly. Additionally, the sensor may not be in the correct position from the start if the printer was not properly calibrated after assembly. Fortunately, fixing the alignment of the daisy wheel is a straightforward process that can be done mostly be done without tools.
  1. How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: passo 1, imagem 1 %32 How to fix alignment on an E-TKT Label Printer, Check the approximate alignment: passo 1, imagem 2 %32
    • Reboot the device.
    • After the splash screen the machine will home by rotating until the magnet meets the hall sensor.
    • Check the letter J position in the top window: If the letter is visually centered (second image), then you can skip ahead to to Step 3.
  2. How to fix alignment on an E-TKT Label Printer, Rough adjustment: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Turn off the device to avoid short circuiting the leads of the hall sensor.
    • Use blunt tweezers to finely adjust the hall sensor position along the tangential (cyan) axis as shown in the image:
    • If J is too much to the right, push the hall sensor toward the centre of the device (yellow arrow).
    • If J is too much to the left, pull the hall sensor towards yourself (magenta arrow).
    • Make sure to keep the same distance on the transversal (red) axis.
  3. How to fix alignment on an E-TKT Label Printer, Fine tuning: passo 3, imagem 1 %32 How to fix alignment on an E-TKT Label Printer, Fine tuning: passo 3, imagem 2 %32
    • Enter the web interface and click on SETUP.
    • Now press the TEST-button to the right side of ALIGN.
    • The machine will now slowly and lightly press the carousel letter, as shown in the second image.
    • Adjust the ALIGN-value until the press is fully centered on the character being pressed.
    • The align value ranges from 1 to 9, with 5 being the default (middle) value.
Conclusão
Happy printing!
Sebastian
Membro desde: 08/19/18
28.526 Reputação
Autoria de 71 guias
Equipe
German Translators Membro de German Translators
Community
35 Membros
Autoria de 1.222 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 14
Ao todo: 133
