Ir para o conteúdo principal
How to clean Microtek ScanMaker 5900 surface glass
O que você precisa
  1. How to clean Microtek ScanMaker 5900 surface glass, Remove serial port connection: passo 1, imagem 1 %32 How to clean Microtek ScanMaker 5900 surface glass, Remove serial port connection: passo 1, imagem 2 %32 How to clean Microtek ScanMaker 5900 surface glass, Remove serial port connection: passo 1, imagem 3 %32
    • Loosen the screws on the serial port by turning them counter clockwise by hand.
    • After loosening the screws, pull the serial port out.
    Pergunte ao FixBot
    Comentar
  2. How to clean Microtek ScanMaker 5900 surface glass, Remove Lid: passo 2, imagem 1 %32 How to clean Microtek ScanMaker 5900 surface glass, Remove Lid: passo 2, imagem 2 %32 How to clean Microtek ScanMaker 5900 surface glass, Remove Lid: passo 2, imagem 3 %32
    • Lift lid to its vertical position.
    • Pull lid straight up to remove it from the scanner.
    Pergunte ao FixBot
    Comentar
  3. How to clean Microtek ScanMaker 5900 surface glass, How to clean Microtek ScanMaker 5900 surface glass: passo 3, imagem 1 %32
    • Using a soft lint-free cloth clean the surface glass of dust, finger prints, and other debris.
    Pergunte ao FixBot
    Comentar
Conclusão
Equipe
Cal Poly, Team 6-9, Regan Fall 2011 Membro de Cal Poly, Team 6-9, Regan Fall 2011
CPSU-REGAN-F11S6G9
2 Membros
Autoria de 22 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 25
Ao todo: 2,148
