Ir para o conteúdo principal
How to adjust Triace A310 Brake Cable
O que você precisa
  1. How to adjust Triace A310 Brake Cable, How to adjust Triace A310 Brake Cable: passo 1, imagem 1 %32 How to adjust Triace A310 Brake Cable, How to adjust Triace A310 Brake Cable: passo 1, imagem 2 %32
    • While holding onto the brake cable, unscrew the screw that holds the brake cable in place using a 5mm allen wrench.
    Pergunte ao FixBot
    Comentar
  2. How to adjust Triace A310 Brake Cable: passo 2, imagem 1 %32
    • If you need to loosen your brakes, pull up on the arm while holding the brake cable in place.
    • To tighten your brakes follow the above step, except push down on the arm instead of pulling up.
    Pergunte ao FixBot
    Comentar
  3. How to adjust Triace A310 Brake Cable: passo 3, imagem 1 %32
    • Tighten the screw on the desired location along the cable with the same 5mm allen wrench.
    Pergunte ao FixBot
    Comentar
Conclusão
You may need to repeat this process until your desired tension is achieved (trial and error).
Ben Hartinger
Membro desde: 01/27/14
340 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 1-37, Maness Winter 2014 Membro de Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Membros
Autoria de 11 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 29
Ao todo: 562
