Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Disassembling the wireless charging pad, to make it as thin as possible.
Inside there is a rubber pad, in order to prevent excessive heat disipating through the back of the charging pad, remove this.
Soldering on thin flexible wires to the + and - on the wireless charging pad
Start by using the USB board replacement guide, step 1 - 8 in order to gain access to the USB board.
Soldering the wireless charging pad connection + to CN2 on the USB port and - to the ground on the USB port, any part of the external metal surface should work.
Use a small file to make room for the wires on the back frame just below where the battery sits.
Using the USB board replacement guide, step 3 - 8 in reverse order to place the back cover, making sure the wires to the charging pad fits through the ready made holes.
Placing the wireless charging pad, slightly off center to keep NFC, which is implemented in the battery, working.
Samsung Galaxy S4 mini booting after fitting wireless charging pad.
11 outras pessoas executaram este guia.
2 comentários
I tryed to copy your guide and soldered everything in place (5V to this usb pin & Ground to the usb-port), messed up the charging coil a bit by ripping off the whole connector (I now have only 2 pads left for soldering to) and if i place it on the dock, the flashy lights on the dock will turn on, but the phone will not charge.
As you said normal charging by usb works fine, but i cant figure out my problem.
Hi Jann
I have used this approach on three different phones, you need to make sure the + connection on the charging pad is soldered onto the connection on the USB port that is marked by the CN2 arrow on the main board.
I had one that showed the same issues you are describing here, taking the phone apart and resoldering the + connection solved that issue.
Best regards
