Ir para o conteúdo principal
How to Wash and Dry Patagonia Waders
O que você precisa
  1. How to Wash and Dry Patagonia Waders, How to Wash and Dry Patagonia Waders: passo 1, imagem 1 %32 How to Wash and Dry Patagonia Waders, How to Wash and Dry Patagonia Waders: passo 1, imagem 2 %32 How to Wash and Dry Patagonia Waders, How to Wash and Dry Patagonia Waders: passo 1, imagem 3 %32
    • Grab your waders and shake out any excess dirt.
    • Zip up any zippers on your waders.
  2. How to Wash and Dry Patagonia Waders: passo 2, imagem 1 %32 How to Wash and Dry Patagonia Waders: passo 2, imagem 2 %32 How to Wash and Dry Patagonia Waders: passo 2, imagem 3 %32
    • Untangle the buckles.
    • Close or clip any fasteners on your buckles.
  3. How to Wash and Dry Patagonia Waders: passo 3, imagem 1 %32
    • Put your waders in the washing machine.
  4. How to Wash and Dry Patagonia Waders: passo 4, imagem 1 %32 How to Wash and Dry Patagonia Waders: passo 4, imagem 2 %32 How to Wash and Dry Patagonia Waders: passo 4, imagem 3 %32
    • Add the technical clothing detergent to the washing machine.
    • We recommend using Granger's Performance Cleaner.
    • Each detergent is slightly different, so you'll want to follow the directions on the package to determine the amount you'll need.
  5. How to Wash and Dry Patagonia Waders: passo 5, imagem 1 %32 How to Wash and Dry Patagonia Waders: passo 5, imagem 2 %32
    • Set the load size on the washing machine to small.
    • Set the water temperature on the washing machine to cold/cold.
    • Some technical washes need to be heat-set, so you'll want to check the directions on the package to determine the best water temperature for your brand of tech wash.
    • Run the washing machine on a gentle or normal wash cycle.
  6. How to Wash and Dry Patagonia Waders: passo 6, imagem 1 %32
    • Once the washer has stopped, run the rinse cycle a second time.
  7. How to Wash and Dry Patagonia Waders: passo 7, imagem 1 %32 How to Wash and Dry Patagonia Waders: passo 7, imagem 2 %32
    • Hang up your waders to dry. You can do this on a laundry line, ladder, or tree branch.
    • Once you are sure that the waders are completely dry, turn them inside-out and allow the inside to dry completely.
  8. How to Wash and Dry Patagonia Waders: passo 8, imagem 1 %32 How to Wash and Dry Patagonia Waders: passo 8, imagem 2 %32 How to Wash and Dry Patagonia Waders: passo 8, imagem 3 %32
    • Alternatively, you can put your waders in the dryer.
    • Place your waders in the dryer.
    • Set the dryer to a normal dry-cycle time on low heat.
    • Start the dryer.
    • You may have to run the dryer for several cycles to get your waders completely dry. Be patient, making sure you rearrange your waders inside the dryer for best results. Make sure they are dry inside and out to prevent the appearance of mold or mildew.
Linha de Chegada
Brittany McCrigler
Membro desde: 03/05/12
89.020 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.299 guias
Um comentário
This was very helpful. Thank you for posting these instructions with easy-to-understand directions and pictures.
J P - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 22
Últimos 30 dias: 80
Duração total: 10,669
