Ir para o conteúdo principal
Repair a Hole in Patagonia Waders
O que você precisa
  1. Repair a Hole in Patagonia Waders, Testing Patagonia Waders For Leaks: passo 1, imagem 1 %32 Repair a Hole in Patagonia Waders, Testing Patagonia Waders For Leaks: passo 1, imagem 2 %32 Repair a Hole in Patagonia Waders, Testing Patagonia Waders For Leaks: passo 1, imagem 3 %32
    • Set up a ladder in a level place outside that you don't mind getting wet.
    • Turn the waders inside out.
    • Clip the waders to the ladder.
  2. Repair a Hole in Patagonia Waders: passo 2, imagem 1 %32 Repair a Hole in Patagonia Waders: passo 2, imagem 2 %32 Repair a Hole in Patagonia Waders: passo 2, imagem 3 %32
    • Put the hose into the waders.
    • Slide the hose into one leg of the waders.
  3. Repair a Hole in Patagonia Waders: passo 3, imagem 1 %32 Repair a Hole in Patagonia Waders: passo 3, imagem 2 %32
    • Turn on the hose and begin to fill the waders.
    • Be sure to pay attention because the large amount of water may tip the ladder. If needed, weigh the back side of the ladder down to prevent it from tipping.
  4. Repair a Hole in Patagonia Waders: passo 4, imagem 1 %32 Repair a Hole in Patagonia Waders: passo 4, imagem 2 %32 Repair a Hole in Patagonia Waders: passo 4, imagem 3 %32
    • Watch for leaks. When you find a leak, mark it with a permanent marker.
    • Repeat this process for the other leg, marking all the leaks you find.
    • Dump the water out and allow the waders to dry completely before you continue.
  5. Repair a Hole in Patagonia Waders, Repair a Hole in Patagonia Waders: passo 5, imagem 1 %32 Repair a Hole in Patagonia Waders, Repair a Hole in Patagonia Waders: passo 5, imagem 2 %32 Repair a Hole in Patagonia Waders, Repair a Hole in Patagonia Waders: passo 5, imagem 3 %32
    • Wipe your marked areas down with an alcohol wipe to clean them.
    • Wait for the area to completely dry before continuing.
  6. Repair a Hole in Patagonia Waders: passo 6, imagem 1 %32
    • Add a drop of Seam Grip to the marked area.
    • You need enough Seam Grip to thinly cover a one-inch square.
  7. Repair a Hole in Patagonia Waders: passo 7, imagem 1 %32 Repair a Hole in Patagonia Waders: passo 7, imagem 2 %32
    • Use the paintbrush to spread the Seam Grip thinly and evenly over the area.
  8. Repair a Hole in Patagonia Waders: passo 8, imagem 1 %32 Repair a Hole in Patagonia Waders: passo 8, imagem 2 %32
    • Rotate your brush 90 degrees and spread the glue evenly over the area.
  9. Repair a Hole in Patagonia Waders: passo 9, imagem 1 %32 Repair a Hole in Patagonia Waders: passo 9, imagem 2 %32 Repair a Hole in Patagonia Waders: passo 9, imagem 3 %32
    • Apply the thin film (included in your wader repair kit) on top of the Seam Grip.
    • Smooth out the film with your finger, pushing out any air bubbles.
    • Allow the waders to sit undisturbed for 12 hours.
  10. Repair a Hole in Patagonia Waders: passo 10, imagem 1 %32 Repair a Hole in Patagonia Waders: passo 10, imagem 2 %32 Repair a Hole in Patagonia Waders: passo 10, imagem 3 %32
    • Peel the thin film off of the waders.
Conclusão
You should now have an invisible, but watertight patch. Repeat this for all of the leaks you marked.
8 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.021 Reputação
Autoria de 131 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 137
Autoria de 17.457 guias
6 comentários
Ho riparato i wader seguendo le indicazioni, ed e stato un trionfo, lavoro perfettamente riuscito. Ora devo provare la tenuta andando a pescare.
Unico problema e il pennarello, che bagnandosi con l’acqua sbava e tende a cancellarsi pur essendo indelebile…. Quando si i Wader si asciugano si rischia di non vedere bene i buchi da riparare se sono di piccola entità.
loris vitali - Responder
Ciao Loris, puoi utilizzare un Markal B Paint Stick per contrassegnare le perdite. Puoi acquistarli su Amazon.
Marty Chapman -
My waders have a nice, round hole about 1/4" in diameter, an inch above the top of the gravel guard. Since Seam Grip can't be applied where there isn't any fabric, a patch is evidently needed, but what to use? LDPE? Tenacious Tape? Other? This is a recent pair of Swiftcurrent waders.
AMG - Responder
Hi AMG, you can actually fix a hole using Seam Grip by either using LDPE on one side or a TPU patch before applying Seam Grip. Because of the location it would be easier to use a TPU patch, the adhesive would keep it in place while applying Seam Grip. Next apply seam grip to the other side liberally, extending past the hole by a 1/2" in all directions. Cover that with either another TPU patch or LDPE film with a flat weighted object to flatten out the repair while it cures. I hope that helps with future DIY endeavors.
Marty Chapman -
How about the seam in the crotch of the waders?
Steve Kyle - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 73
Últimos 30 dias: 366
Duração total: 19,633
