Ir para o conteúdo principal
How to True a Bent Bicycle Rim Using Common Tools
O que você precisa
    1. How to True a Bent Bicycle Rim Using Common Tools, How to True a Bent Bicycle Rim Using Common Tools: passo 1, imagem 1 %32
      • Bring your bike somewhere with ample space so you have room to work.
      Pergunte ao FixBot
      Comentar
    2. How to True a Bent Bicycle Rim Using Common Tools: passo 2, imagem 1 %32 How to True a Bent Bicycle Rim Using Common Tools: passo 2, imagem 2 %32 How to True a Bent Bicycle Rim Using Common Tools: passo 2, imagem 3 %32
      • Flip the bike on its seat so the wheel can spin freely.
      • Use the spokes to spin the affected wheel.
      • Continue spinning the wheel until it is clear where the bend is occurring.
      Pergunte ao FixBot
      Comentar
    3. How to True a Bent Bicycle Rim Using Common Tools: passo 3, imagem 1 %32 How to True a Bent Bicycle Rim Using Common Tools: passo 3, imagem 2 %32
      • Locate the bend by spinning the wheel to see where it doesn't align with the brake.
      Pergunte ao FixBot
      Comentar
    4. How to True a Bent Bicycle Rim Using Common Tools: passo 4, imagem 1 %32 How to True a Bent Bicycle Rim Using Common Tools: passo 4, imagem 2 %32 How to True a Bent Bicycle Rim Using Common Tools: passo 4, imagem 3 %32
      • Locate the two nearest spoke nipples opposite to the bend direction and tighten them a half turn using an adjustable wrench or reaming pliers.
      Pergunte ao FixBot
      Comentar
    5. How to True a Bent Bicycle Rim Using Common Tools: passo 5, imagem 1 %32 How to True a Bent Bicycle Rim Using Common Tools: passo 5, imagem 2 %32
      • Pluck the spoke and listen to the pitch to check its tightness.
      • If the pitch is higher, you are tightening it, and if the pitch is lower, you are loosening it.
      Pergunte ao FixBot
      Comentar
    6. How to True a Bent Bicycle Rim Using Common Tools: passo 6, imagem 1 %32 How to True a Bent Bicycle Rim Using Common Tools: passo 6, imagem 2 %32
      • Loosen the spoke nipples opposite to the ones being tightened to reduce stress in the wrong direction.
      Pergunte ao FixBot
      Comentar
    7. How to True a Bent Bicycle Rim Using Common Tools: passo 7, imagem 1 %32
      • Assess the dent in the bike rim and assure it's mostly straightened out relative to the break pad.
      • Repeat the tightening/loosening process accordingly if necessary.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Equipe
UCD-MORRIS-S23S1G4 Membro de UCD-MORRIS-S23S1G4
Community
2 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 61
Ao todo: 2,232
