Ir para o conteúdo principal
How to Shure SM58
O que você precisa
  1. How to Shure SM58, Collar: passo 1, imagem 1 %32 How to Shure SM58, Collar: passo 1, imagem 2 %32 How to Shure SM58, Collar: passo 1, imagem 3 %32
    • Grab the microphone base with one hand. With the other hand, grab just below the grille (the collar). Twist the collar clockwise to loosen it.
    • Be careful to not pull on the collar or you may rip the wires from the faceplate.
  2. How to Shure SM58, How to Shure SM58: passo 2, imagem 1 %32 How to Shure SM58, How to Shure SM58: passo 2, imagem 2 %32
    • Plug the soldering iron in and let it heat up for five minutes.
  3. How to Shure SM58: passo 3, imagem 1 %32
    what is the gauge of the wire please
    Yosef ymj - Responder
  4. How to Shure SM58: passo 4, imagem 1 %32
    • Bend the wire around the contact point.
    • The yellow wire goes to the contact above the red lettering.
    • The green wire goes on the contact point with a “+” next to it.
  5. How to Shure SM58: passo 5, imagem 1 %32
    • In one hand, hold the solder. In the other hold your soldering iron.
    • Touch both the soldering iron and the solder to the contact point. The solder should melt and forge a connection to the face plate.
  6. How to Shure SM58: passo 6, imagem 1 %32
    • First, remove the solder and then the soldering iron from the contact point.
    • If you remove the soldering iron first, the solder may become stuck to the contact point.
    • Let the wire cool for 30 seconds or so.
  7. How to Shure SM58: passo 7, imagem 1 %32
    • If your wire is not completely connected, repeat steps 2-5 until the wire is reconnected.
Conclusão
After soldering, all of your wiring should be connected to the Faceplate inside of the microphone.
5 outras pessoas executaram este guia.
nat coll
Membro desde: 09/27/12
642 Reputação
Autoria de 14 guias
Equipe
Cal Poly, Team 7-53, Forte Fall 2012 Membro de Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
Membros da 5
Autoria de 20 guias
3 comentários
I just want to say Thank you! Simple complete instruction. Couldn't be easier.
Steve Segura - Responder
I don't have a + on my plate, but several marks like one resembling Z, another one BB overlapped by 82 and A in the corner. Also I have 3 connection points (middle one is perhaps the black wire?), and 2 pairs of yellows and greens. Since I have version with switch, I suspect one pair of yellow and green being direct bypasses of the mic (you can see it coming from deeper in the body, while the other pair coming straight from the switch connection points).
In any case, how do I find out which colour for which connection point?
zetninetynine - Responder
I couldn't tell you without looking at the mic, however I am sure you could find the answer by googling it and reading through forums. What exactly are you trying to do to the mic?
Daniel Berger -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 10
Últimos 7 dias: 60
Últimos 30 dias: 256
Duração total: 31,316
