Ir para o conteúdo principal
How to Shorten a Watch Band
O que você precisa
  1. How to Shorten a Watch Band, How to Shorten a Watch Band: passo 1, imagem 1 %32
    • Open the watch band.
  2. How to Shorten a Watch Band: passo 2, imagem 1 %32
    • Find the arrows inside the band and place the watch so the arrows are facing down.
  3. How to Shorten a Watch Band: passo 3, imagem 1 %32
    • Place a nail in the hole on the opposite side of the arrow.
    • Gently tap the nail into the hole with a small hammer.
  4. How to Shorten a Watch Band: passo 4, imagem 1 %32
    • Remove the pin from the hole of the watch link.
    • Remove the watch link.
  5. How to Shorten a Watch Band: passo 5, imagem 1 %32 How to Shorten a Watch Band: passo 5, imagem 2 %32
    • Repeat Steps 3 and 4 until the watch band is the desired size.
  6. How to Shorten a Watch Band: passo 6, imagem 1 %32 How to Shorten a Watch Band: passo 6, imagem 2 %32
    • Join the clock's bands and insert the pin in the same direction as the arrow until it is sealed.
Linha de Chegada
7 outras pessoas executaram este guia.
1Comentário do guia
Never knew how easy it was until I went through this guide. Appreciate how simple you made it
Thomas Legrand - Responder
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 62
Últimos 30 dias: 245
Ao todo: 23,820
