Ir para o conteúdo principal
How to Restore or Apply an Oleophobic Coating
O que você precisa
  1. How to Restore or Apply an Oleophobic Coating, Clean the surface: passo 1, imagem 1 %32 How to Restore or Apply an Oleophobic Coating, Clean the surface: passo 1, imagem 2 %32
    Ferramenta utilizada neste passo:
    Microfiber Cleaning Cloths
    $3.99
    • Use isopropyl alcohol to thoroughly clean the surface you are planning to apply the coating to.
    • Wipe the screen dry with a clean microfiber cloth.
  2. How to Restore or Apply an Oleophobic Coating, Prepare a wiping finger: passo 2, imagem 1 %32 How to Restore or Apply an Oleophobic Coating, Prepare a wiping finger: passo 2, imagem 2 %32 How to Restore or Apply an Oleophobic Coating, Prepare a wiping finger: passo 2, imagem 3 %32
    • Read the next three steps before you attempt the procedure. The oleophobic coating's liquid solvent evaporates very quickly when applied, so you'll need to work quickly.
    • Wrap one finger in a bit of plastic. You can use a sandwich bag or some plastic wrap.
    • You will use this covered finger to rub the coating liquid onto the screen. This will prevent your finger from absorbing the liquid.
  3. How to Restore or Apply an Oleophobic Coating, Apply the coating to the surface: passo 3, imagem 1 %32 How to Restore or Apply an Oleophobic Coating, Apply the coating to the surface: passo 3, imagem 2 %32 How to Restore or Apply an Oleophobic Coating, Apply the coating to the surface: passo 3, imagem 3 %32
    • Apply 10-15 drops of the oleophobic coating liquid onto the surface.
    • If you are coating a large surface such as a large phone or tablet, apply ten drops to a portion of the screen, and work on one portion at a time.
  4. How to Restore or Apply an Oleophobic Coating, Distribute the coating: passo 4, imagem 1 %32 How to Restore or Apply an Oleophobic Coating, Distribute the coating: passo 4, imagem 2 %32 How to Restore or Apply an Oleophobic Coating, Distribute the coating: passo 4, imagem 3 %32
    • Wipe your plastic-covered finger over the surface with quick, light swipes until the liquid evaporates.
    • You don't need to rub very hard—you're just spreading out the coating molecules onto the surface before the solvent evaporates.
    • If you applied the liquid to only a portion of the surface, repeat the liquid application and rubbing procedure to the remaining surface.
  5. How to Restore or Apply an Oleophobic Coating, Give the coating time to set: passo 5, imagem 1 %32
    • Do not touch the surface for 8-12 hours in order to allow the coating to bond to the surface.
    • For best results, apply the coating before bedtime, so it has all night to bond.
    • Afterward, you can wipe off any residue remaining on the touch screen with a clean microfiber cloth.
    • Repeat this process 2-3 times to fully maximize the oleophobic coating performance and film durability.
Conclusão
Done properly, this results in a perfect oleophobic coating on your device.
Your device will still collect some fingerprints, but the oil left behind by your fingers will be greatly reduced, and easier to wipe off.
Reapply the coating every 1-2 months or as needed.
279 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
334.370 Reputação
Autoria de 847 guias
61Comentários do guia
Very interesting guide. Awesome.
Do I have to remove the coating that is on the device when it's new?
Especially when the coating has some very small scratches?
And if yes, how to remove it?
Thanks
Peter Gordon - Responder Compartilhar
apply Acetone
Mudiver - Compartilhar
I recommend avoiding this for the iPhone 6. The curved screen simply directs the liquid into the casing.
Alex Pappajohn - Responder Compartilhar
Tried this with my iPhone 6. Seems to work pretty well. I'll do a few more quotes. I noticed this actually had a beneficial effect on screen scratches. Filled them in pretty well, blends with the screen more.
Talk about a happy accident!
ckeyser - Responder Compartilhar
one comment says not to use it with iPhone 6 and another one says it worked ok, so what do I do? is it any dangerous? because I bought it before your last comments but I still havent used it since I'm worried about what can happen
Salvador Martinez - Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 145
Últimos 7 dias: 961
Últimos 30 dias: 4,306
Ao todo: 720,207
