Ir para o conteúdo principal
How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.
O que você precisa
  1. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower., How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 1, imagem 1 %32
    • Start with a flat, open space to work.
  2. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 2, imagem 1 %32 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 2, imagem 2 %32
    • Unscrew these three 1.2 mm screws.
  3. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 3, imagem 1 %32
    • Remove the Bubble Sprocket from the motor.
  4. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 4, imagem 1 %32
    • Unscrew these four 1.2mm screws holding the plate on.
  5. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 5, imagem 1 %32
    • Remove the plate.
  6. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 6, imagem 1 %32
    • Connect the red wire to the top right pin.
  7. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 7, imagem 1 %32
    • Solder the Red wire to the metal pin.
    • (Warning Soldering is very hot!)
  8. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 8, imagem 1 %32 How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 8, imagem 2 %32
    • Connect the yellow wire to the bottom right pin.
    • Solder the yellow wire to the bottom right pin.
    • (Warning Soldering iron is very hot!)
  9. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 9, imagem 1 %32
    • Replace the plate over the wires.
  10. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 10, imagem 1 %32
    • Put four 1.2 mm screws for the plate back into place.
  11. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 11, imagem 1 %32
    • Put three 1.2mm screws for the motor back into place.
  12. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 12, imagem 1 %32
    • Insert the Bubble sprocket onto the motor.
  13. How to Repair the Electrical Connections on a Little Tikes Motorized Bubble Mower.: passo 13, imagem 1 %32
    • You are now finished!
Linha de Chegada
John Hiller
Membro desde: 10/05/15
110 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 1,807
