Introdução
In this guide, you will learn how to repair a frayed or damaged lightning cable by stripping the wire near the damaged area and using a soldering iron to ensure a solid connection.
O que você precisa
Locate the damaged area of your lightning cable.
Use the 1.6 mm gauge on the wire strippers to strip a small portion of the outer jacket.
Peel the outer jacket from both sides of the damaged area, exposing the underlying metal jacket.
Conclusão
Repeat for any other damaged areas on lightning cable.
