Ir para o conteúdo principal
How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery
O que você precisa
  1. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery, Battery: passo 1, imagem 1 %32 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery, Battery: passo 1, imagem 2 %32 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery, Battery: passo 1, imagem 3 %32
    • Set your gel blaster flat on a table.
    • Push the battery compartment release tab upwards.
    • Lift the battery cover and remove it.
  2. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: passo 2, imagem 1 %32 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: passo 2, imagem 2 %32 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: passo 2, imagem 3 %32
    • Squeeze both the left and the right side of the release latch and pull apart the connector to remove the battery from the gel blaster's motor.
  3. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: passo 3, imagem 1 %32
    • Remove the battery from the battery compartment.
  4. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: passo 4, imagem 1 %32 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: passo 4, imagem 2 %32
    • Use utility scissors to cut the first green layer of the battery.
    • Remove the first layer to expose the connection to the wire.
    • Be careful when cutting the top layer, and do not remove the inner plastic layer.
  5. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: passo 5, imagem 1 %32 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: passo 5, imagem 2 %32
    • Using the soldering iron and the lead-free solder, re-solder the wire to the battery to ensure a stable connection.
    • If there is any confusion on how to solder, please refer to the link below: How To Solder and Desolder Connections
  6. How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: passo 6, imagem 1 %32 How to Repair an Anstoy Electric AKM-47 Gel Blaster Battery: passo 6, imagem 2 %32
    • Insert the battery back into the battery compartment.
    • Reconnect the battery to the motor.
    • Replace the cover to close the battery compartment.
Conclusão
Bryan Mendoza
Membro desde: 02/10/23
145 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 13
Últimos 30 dias: 85
Duração total: 857
