Ir para o conteúdo principal
How to Repair a Wooden Picture Frame
O que você precisa
  1. How to Repair a Wooden Picture Frame, How to Repair a Wooden Picture Frame: passo 1, imagem 1 %32
    • Pull back the metal clips that hold the frame, you may use the pliers to pull them back if needed.
    • Remove the back of the frame and find a safe spot for it. You will need it at the end of the guide to put it back together.
    • If the glass seem's to be cracked, handle the frame gently and wear gloves to prevent injury
  2. How to Repair a Wooden Picture Frame: passo 2, imagem 1 %32
    • After clamps are lifted, carefully remove glass out of the frame. You may use the pliers for this step to lift the clamps
    • If glass is broken as mentioned in the first step, carefully remove it with safety gloves to prevent from injury
  3. How to Repair a Wooden Picture Frame: passo 3, imagem 1 %32
    • Begin to pull apart any loose joints that may be embedded in the frame with the needle nose pliers
  4. How to Repair a Wooden Picture Frame: passo 4, imagem 1 %32
    • Begin to sand off the finish with the sandpaper if the frame appears to be scratched or damaged in any way
    • Sand by hand, this appears to be the easiest way to approach the wood, going along with the grain.
    • Continue to sand out the scratches until smooth as you remove the finish.
  5. How to Repair a Wooden Picture Frame: passo 5, imagem 1 %32
    • If you proceeded to sand the frame, or not, restoring the color of the wood gives it a great finish and shine.
    • Take your paint brush and lightly dip it into the stain, covering all parts of the frame. Proceed to let sit for 1 hour until dry.
  6. How to Repair a Wooden Picture Frame: passo 6, imagem 1 %32
    • Using carpenter glue, glue the joint(s) back together and apply pressure when pressing sides together using your hands.
    • You may use clamps on the joints if repairing all four sides of the frame, for better structure.
    • Let glue sit to dry overnight.
  7. How to Repair a Wooden Picture Frame: passo 7, imagem 1 %32
    • After letting sit overnight, your glue should be dry and your frame should be as good as new!
    • Be sure to replace any glass that may had been broken when the frame collapsed.
    • Measure any dimensions with a tape measure to get an exact measurement of the glass, then cut with a glass cuter.
    • Insert new glass onto frame, and push down side clamps.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 14
Últimos 30 dias: 62
Ao todo: 11,806
