Ir para o conteúdo principal
How to Repair a Painting Frame
O que você precisa
  1. How to Repair a Painting Frame, How to Repair a Painting Frame: passo 1, imagem 1 %32 How to Repair a Painting Frame, How to Repair a Painting Frame: passo 1, imagem 2 %32 How to Repair a Painting Frame, How to Repair a Painting Frame: passo 1, imagem 3 %32
    • Wipe the frame with a damp cloth.
  2. How to Repair a Painting Frame: passo 2, imagem 1 %32
    • Use a paper plate to mix the epoxy adhesives with a wooden stick.
    • Follow the instructions on your specific package of epoxy adhesive.
    • Make sure to use the glue within 45 minutes after mixing.
  3. How to Repair a Painting Frame: passo 3, imagem 1 %32
    • Flip the glass painting and remove the frame joints.
  4. How to Repair a Painting Frame: passo 4, imagem 1 %32 How to Repair a Painting Frame: passo 4, imagem 2 %32 How to Repair a Painting Frame: passo 4, imagem 3 %32
    • Use a wooden stick to apply a thin layer of glue on the edges of the frame.
  5. How to Repair a Painting Frame: passo 5, imagem 1 %32 How to Repair a Painting Frame: passo 5, imagem 2 %32 How to Repair a Painting Frame: passo 5, imagem 3 %32
    • Put the glass painting over the glue and close the frame's metal clamps.
  6. How to Repair a Painting Frame: passo 6, imagem 1 %32
    • Seal the clamps with duct tape for protection.
    • Repeat Steps 5-7 on all sides of the painting. It is suggested to place painting over the surface so it will be easier to apply the glue.
    • Once all four sides are done, clamp the corners with safety tape.
    • Let the glue dry for a minimum of 24 hours.
  7. How to Repair a Painting Frame: passo 7, imagem 1 %32 How to Repair a Painting Frame: passo 7, imagem 2 %32
    • Remove all the tape from the metal clamps and the corners of the frame.
  8. How to Repair a Painting Frame: passo 8, imagem 1 %32
    • After that, you will have a restored painting frame.
Linha de Chegada
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 800
