Ir para o conteúdo principal
How to Remove Rust from a Screwdriver
O que você precisa
    1. How to Remove Rust from a Screwdriver, How to Remove Rust from a Screwdriver: passo 1, imagem 1 %32 How to Remove Rust from a Screwdriver, How to Remove Rust from a Screwdriver: passo 1, imagem 2 %32 How to Remove Rust from a Screwdriver, How to Remove Rust from a Screwdriver: passo 1, imagem 3 %32
      • Use a clean rag to wipe the screwdriver to remove any dirt, grease, or debris.
      Pergunte ao FixBot
      Comentar
    2. How to Remove Rust from a Screwdriver: passo 2, imagem 1 %32 How to Remove Rust from a Screwdriver: passo 2, imagem 2 %32 How to Remove Rust from a Screwdriver: passo 2, imagem 3 %32
      • In a bowl, stir half a tablespoon of baking soda with 4 to 5 drops of water.
      • Add one eighth teaspoon of baking soda if the mixture is too runny, or 4 to 5 drops of water if the paste is too thick.
      • Adjust the amount of baking soda and water based on the size of the screwdriver.
      Pergunte ao FixBot
      Comentar
    3. How to Remove Rust from a Screwdriver: passo 3, imagem 1 %32 How to Remove Rust from a Screwdriver: passo 3, imagem 2 %32 How to Remove Rust from a Screwdriver: passo 3, imagem 3 %32
      • Apply the paste with moderate pressure, while making sure to fully cover all the rusted areas on the screwdriver.
      • If too much pressure is applied, the paste will fall off. If too little pressure is applied, the paste won't stick.
      Pergunte ao FixBot
      Comentar
    4. How to Remove Rust from a Screwdriver: passo 4, imagem 1 %32
      • Allow the paste to sit on the rusted areas for 2 to 6 hours.
      • For heavily rusted screwdrivers, let the paste sit overnight.
      Pergunte ao FixBot
      Comentar
    5. How to Remove Rust from a Screwdriver: passo 5, imagem 1 %32 How to Remove Rust from a Screwdriver: passo 5, imagem 2 %32 How to Remove Rust from a Screwdriver: passo 5, imagem 3 %32
      • After 2 to 6 hours, use a toothbrush or some sort of brush to scrub the paste off the screwdriver.
      • Apply moderate pressure in back and forth and circle motions to effectively remove the rust.
      Pergunte ao FixBot
      Comentar
    6. How to Remove Rust from a Screwdriver: passo 6, imagem 1 %32 How to Remove Rust from a Screwdriver: passo 6, imagem 2 %32 How to Remove Rust from a Screwdriver: passo 6, imagem 3 %32
      • Rinse the screwdriver with clean water to remove any remaining paste.
      • Hot water that can be comfortably handled will remove the paste better.
      • Do not use boiling water, otherwise you can injure yourself. Make sure to use hot tap water.
      Pergunte ao FixBot
      Comentar
    7. How to Remove Rust from a Screwdriver: passo 7, imagem 1 %32 How to Remove Rust from a Screwdriver: passo 7, imagem 2 %32 How to Remove Rust from a Screwdriver: passo 7, imagem 3 %32
      • Using a clean rag, dry the screwdriver by wiping it in a back and forth motion.
      • Make sure the screwdriver is fully dry, otherwise the rust can return.
      Pergunte ao FixBot
      Comentar
Linha de Chegada
4 outras pessoas executaram este guia.
Varun Sharma
Membro desde: 07/03/24
253 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 40
Últimos 30 dias: 127
Ao todo: 1,574
