Ir para o conteúdo principal
How to Reinforce a Microbead Plush
O que você precisa
  1. How to Reinforce a Microbead Plush, How to Reinforce a Microbead Plush: passo 1, imagem 1 %32 How to Reinforce a Microbead Plush, How to Reinforce a Microbead Plush: passo 1, imagem 2 %32 How to Reinforce a Microbead Plush, How to Reinforce a Microbead Plush: passo 1, imagem 3 %32
    • Look for seams in the microbead plush that you can tear to remove its contents.
    • Using a seam ripper, make a hole the size of your thumb.
    • You can enlarge the hole if needed.
    • Make sure that you follow the seam when you make the hole.
  2. How to Reinforce a Microbead Plush: passo 2, imagem 1 %32 How to Reinforce a Microbead Plush: passo 2, imagem 2 %32 How to Reinforce a Microbead Plush: passo 2, imagem 3 %32
    • Dump out the contents of the plush into a large container using that hole you made.
    • Make sure not to let the plush touch the beads. They will stick to the plush.
  3. How to Reinforce a Microbead Plush: passo 3, imagem 1 %32 How to Reinforce a Microbead Plush: passo 3, imagem 2 %32 How to Reinforce a Microbead Plush: passo 3, imagem 3 %32
    • Flip the plush inside out using the hole you made.
    • Be wary that some micro-beads may still be stuck to the inside of the fabric.
  4. How to Reinforce a Microbead Plush: passo 4, imagem 1 %32 How to Reinforce a Microbead Plush: passo 4, imagem 2 %32 How to Reinforce a Microbead Plush: passo 4, imagem 3 %32
    • Fold the inside-out casing in half.
    • Place it on a piece of fabric folded into fourths. The loose ends of the fabric should be facing you.
    • Trace the outline of the casing with a marker.
  5. How to Reinforce a Microbead Plush: passo 5, imagem 1 %32 How to Reinforce a Microbead Plush: passo 5, imagem 2 %32
    • Use scissors to cut out the outline of the plush.
    • You may use safety pins on the inside of the outline so the fabric doesn't slip.
    • You can use the casing as a guide if you're unsure with your outline.
  6. How to Reinforce a Microbead Plush: passo 6, imagem 1 %32 How to Reinforce a Microbead Plush: passo 6, imagem 2 %32 How to Reinforce a Microbead Plush: passo 6, imagem 3 %32
    • Measure about 20 times the length of the plush in thread.
    • Push the thread through the eye of the needle until both sides of the needle have an equal amount of thread.
    • Check out Repairing a Stuffed Teddy if you're unsure how to thread a needle.
    • Create a small loop using the loose ends, leaving about 2 centimeters to wrap around the base of the loop. Push the excess through the loop to create a knot.
  7. How to Reinforce a Microbead Plush: passo 7, imagem 1 %32 How to Reinforce a Microbead Plush: passo 7, imagem 2 %32 How to Reinforce a Microbead Plush: passo 7, imagem 3 %32
    • Unfold the material keeping both outline sheets together.
    • This will create a bag for the microbeads to go in.
    • After unfolding, use a different color marker to note where the hole made in step one is on your plush.
    • Do not close this hole as this is the refilling point.
    • Start stitching along the edge of the outlines, weaving the needle every centimeter to close any gaps.
  8. How to Reinforce a Microbead Plush: passo 8, imagem 1 %32 How to Reinforce a Microbead Plush: passo 8, imagem 2 %32 How to Reinforce a Microbead Plush: passo 8, imagem 3 %32
    • Stuff the bag into the plush, leaving the openings together.
    • Sew the edges of the openings onto the plush to prevent the bag from slipping when refilling.
    • Insert the funnel in the opening and begin refiling the plush.
    • Refill the plush slowly using a cup to avoid spilling the microbeads over the plush.
  9. How to Reinforce a Microbead Plush: passo 9, imagem 1 %32 How to Reinforce a Microbead Plush: passo 9, imagem 2 %32 How to Reinforce a Microbead Plush: passo 9, imagem 3 %32
    • After refilling the plush, sew the opening closed.
    • After closing the opening press down on the plush to spread around the microbeads.
Conclusão
With those final stitches, your microbead plush shouldn’t spill anymore.
Oscar Olivares
Membro desde: 03/19/22
169 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 17
Ao todo: 571
