Introdução
This guide will show you how to repair/refurbish a stuffed animal or teddy bear. However, these skills can be used on any stuffed object. Be aware when using scissors and a sharp needle; take any precautions to avoid misuse or injury. Prior sewing and knot tying knowledge is necessary. Adequate lighting is recommended.
Ferramentas
Peças
Nenhum componente especificado.
Gather all necessary materials as listed on the bottom of the page. Be sure you have a clean, clear place to work with lots of light.
Now that the stuffed animal is re-stuffed, the incision needs to be sewn closed. Thread a needle with thread matching the fabric of the stuffed animal by pushing the thread through the small hole (eye) of the needle.
Choose the length of your thread based on the length of the incision. Approx. 2-3 feet of thread will work well for a 3 inch incision.
Starting at one end of the incision, insert the needle through a small section of the fabric, pull until the tail end of the thread is about 2 inches from being pulled through the fabric. Grab the tail of the thread and tie it to the base of the thread you pulled through the fabric. Tuck the short excess tail thread into the stuffed animal.
Create small stitches joining the two sides along the length of the incision. Keep stitches tight and close together.
Replacing a Missing Eye
Gather all necessary supplies
3 outras pessoas concluíram este guia.
