Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
In this guide, we will be demonstrating the repair of a support bracket that has detached from the moving bracket assembly in a Hamilton Beach toaster. When you are finished with this repair, your toaster will be fully functional again.
The support bracket is the part of a toaster that holds the bread. If the support bracket is broken, you will not be able lower bread into the toaster or lift it out using the toasting lever.
This repair requires very little background knowledge or repair experience. However, you will need some patience and a steady hand. It might be helpful to have an assistant help you complete this repair.
O que você precisa
Remove all five 5mm Phillips #1 screws from the bottom of the toaster.
Follow these steps and your toaster will be as good as new!
