Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove all five 5mm Phillips #1 screws from the bottom of the toaster.
Lift the top of the toaster from the bottom section of the toaster.
Look into the toaster and locate the two divots that the support bracket has detached from.
Use the portion of the bracket that is sticking out of the back of the toaster to move the support bracket.
Align the support bracket with the two divots on the moving bracket assembly.
Using moderate force, push the teeth of the support bracket into the divots on the moving bracket assembly.
Carefully lower the shell of the toaster back down to its base.
Lift and lower the toasting lever a few times to ensure that the support bracket is firmly in place.
Screw on the bottom of the toaster using all five 5mm Phillips #1 screws.
