Ir para o conteúdo principal
How to Reattach a Backpack Grab Handle
O que você precisa
    1. How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: passo 1, imagem 1 %32 How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: passo 1, imagem 2 %32 How to Reattach a Backpack Grab Handle, How to Reattach a Backpack Grab Handle: passo 1, imagem 3 %32
      • Use a pair of scissors to open the seam on the backpack where the grab handle was torn off.
      • Caution: Be careful when using scissors this way.
      Pergunte ao FixBot
      Comentar
    2. How to Reattach a Backpack Grab Handle: passo 2, imagem 1 %32 How to Reattach a Backpack Grab Handle: passo 2, imagem 2 %32
      • Open up the inner seam at the same spot using a pair of scissors.
      Pergunte ao FixBot
      Comentar
    3. How to Reattach a Backpack Grab Handle: passo 3, imagem 1 %32 How to Reattach a Backpack Grab Handle: passo 3, imagem 2 %32
      • Get your sewing needle and thread with a colour that matches the area on the backpack being repaired.
      Pergunte ao FixBot
      Comentar
    4. How to Reattach a Backpack Grab Handle: passo 4, imagem 1 %32 How to Reattach a Backpack Grab Handle: passo 4, imagem 2 %32 How to Reattach a Backpack Grab Handle: passo 4, imagem 3 %32
      • Thread your sewing needle.
      • Make sure your thread is doubled; this makes it more durable and less likely for your stitching to come apart.
      Pergunte ao FixBot
      Comentar
    5. How to Reattach a Backpack Grab Handle: passo 5, imagem 1 %32 How to Reattach a Backpack Grab Handle: passo 5, imagem 2 %32 How to Reattach a Backpack Grab Handle: passo 5, imagem 3 %32
      • Hold the edge of your grab handle down at the the first seam you opened.
      • Use the threaded needle to stitch the end of the handle to that spot, then cut off the thread and tie it into a knot.
      • Caution: Sewing needles are sharp; be careful not to poke yourself.
      • This repair only requires one of these two basic stitching methods.
      Pergunte ao FixBot
      Comentar
    6. How to Reattach a Backpack Grab Handle: passo 6, imagem 1 %32 How to Reattach a Backpack Grab Handle: passo 6, imagem 2 %32
      • Hold down the second seam you opened, over the reattached grab handle, and stitch it closed.
      • Use one of these basic stitching methods.
      Pergunte ao FixBot
      Comentar
    7. How to Reattach a Backpack Grab Handle: passo 7, imagem 1 %32 How to Reattach a Backpack Grab Handle: passo 7, imagem 2 %32 How to Reattach a Backpack Grab Handle: passo 7, imagem 3 %32
      • Cut off the remaining thread and tie it into a knot.
      Pergunte ao FixBot
      Comentar
Conclusão
Once you have completed this guide, you will be able to make use of your grab handle once again.
5 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 35
Últimos 30 dias: 193
Ao todo: 11,632
