Ir para o conteúdo principal
How to Patch a Ripped Backpack
O que você precisa
    1. How to Patch a Ripped Backpack, Identify the repair area: passo 1, imagem 1 %32 How to Patch a Ripped Backpack, Identify the repair area: passo 1, imagem 2 %32 How to Patch a Ripped Backpack, Identify the repair area: passo 1, imagem 3 %32
      • Identify the defective area and assess how large the damage is.
      Pergunte ao FixBot
      Comentar
    2. How to Patch a Ripped Backpack, Prepare for patching: passo 2, imagem 1 %32 How to Patch a Ripped Backpack, Prepare for patching: passo 2, imagem 2 %32 How to Patch a Ripped Backpack, Prepare for patching: passo 2, imagem 3 %32
      • Use a pair of scissors to cut the loose threads and clean the area.
      • Use a similar color fabric to create your "own patch".
      • Tip: Cut a piece of fabric that is at least 1cm bigger than the tear (from each side). Use a sewing machine to create a hem around the border of the patch.
      Pergunte ao FixBot
      Comentar
    3. How to Patch a Ripped Backpack, Pin the area: passo 3, imagem 1 %32 How to Patch a Ripped Backpack, Pin the area: passo 3, imagem 2 %32 How to Patch a Ripped Backpack, Pin the area: passo 3, imagem 3 %32
      • Use sewing pins to pin the area and set the patch in place.
      • Start sewing follow the shape of the patch.
      Pergunte ao FixBot
      Comentar
    4. How to Patch a Ripped Backpack, Continue stitching: passo 4, imagem 1 %32 How to Patch a Ripped Backpack, Continue stitching: passo 4, imagem 2 %32 How to Patch a Ripped Backpack, Continue stitching: passo 4, imagem 3 %32
      • Once you have stitched the first side of the patch. Apply more sewing pins to set the patch in place and continue sewing.
      • Tip: In this example, a square patch was used to repair the tear. For aesthetic reasons, a “triangle” shape was achieved by inserting part of the patch inside the tear and folding one side inward.
      Pergunte ao FixBot
      Comentar
    5. How to Patch a Ripped Backpack, Finished and ready!: passo 5, imagem 1 %32 How to Patch a Ripped Backpack, Finished and ready!: passo 5, imagem 2 %32 How to Patch a Ripped Backpack, Finished and ready!: passo 5, imagem 3 %32
      • 🛠️🏆👏 Congratulations! The repair is complete, and you're ready to go!
      Pergunte ao FixBot
      Comentar
Conclusão
In need of another repair? Don't worry! Check out our other guides to find quick solutions for your favourite clothing, footwear and equipment!
🚨🛠️🩹 IMPORTANT SAFETY NOTICE:
The repair guides provided on this site are intended to help you repair products on your own. While we have put a lot of care into them, all repair work carries some risk:
  1. Safety Precautions: When repairing your product, take all necessary precautions to ensure your safety. Use appropriate tools and follow the instructions carefully.
  2. Product Condition: Once your product has been repaired, it may not meet original compliance guidelines anymore and could potentially have issues.
  3. Liability: We are not responsible for any damage or injury that may occur during the repair process or as a result of using a repaired product. You, as the repairer, assume all risks and responsibilities associated with the repair.
By using these repair guides, you fully acknowledge and accept the potential risks and responsibilities involved.
Ben Blischke
Membro desde: 07/19/23
10.548 Reputação
Autoria de 68 guias
Equipe
INTERSPORT Membro de INTERSPORT
Community
25 Membros
Autoria de 179 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 61
Ao todo: 983
