Introdução
Use this guide to open the Xiaomi Mi Watch 2021 and remove the rear case assembly.
O que você precisa
Before starting the disassembly, turn off your watch.
Remove the four 3.2 mm-long T3 Torx screws on the back of the watch.
Insert the flat end of a spudger into the loudspeaker opening at the top edge of the rear case assembly.
Push the spudger upwards to create a small gap between the rear case assembly and the watch housing.
Insert your spudger into the gap and pry up the rear case assembly.
Carefully swing open the rear case assembly by folding the rear case to the side with the watch buttons.
