Introdução
Use this guide to remove the back cover of the Samsung Galaxy Watch4 Classic.
O que você precisa
Before starting repairs, take your watch off the charger and power it down.
Remove the watch band.
Use a Tri-point Y00 screwdriver to remove the four 4.0 mm-long screws securing the back cover.
Insert an opening tool into the seam between the back cover and the metal housing.
Twist the opening tool to create a gap.
Lay the watch face down.
Carefully swing open the back cover by folding it to the opposite site of the created gap.
Use the flat end of a spudger to pry up and disconnect the sensor flex cable from the motherboard.
Um comentário
back cover rubber gasket, where can you find this? or is T-8000 glue ok?
