Ir para o conteúdo principal
How to Open the Huawei Watch GT 2 (42 mm)
O que você precisa
  1. How to Open the Huawei Watch GT 2 (42 mm), Remove the watch band: passo 1, imagem 1 %32
    • Before starting the repairs, take your watch off the charger and power it down.
    • Remove the watch band.
  2. How to Open the Huawei Watch GT 2 (42 mm), Unfasten the screws: passo 2, imagem 1 %32
    • Use a T2 Torx screwdriver to remove the four 3.6 mm screws securing the back cover assembly.
  3. How to Open the Huawei Watch GT 2 (42 mm), Pry up the back cover assembly: passo 3, imagem 1 %32 How to Open the Huawei Watch GT 2 (42 mm), Pry up the back cover assembly: passo 3, imagem 2 %32 How to Open the Huawei Watch GT 2 (42 mm), Pry up the back cover assembly: passo 3, imagem 3 %32
    • Insert an opening tool in the seam on the top edge between the back cover assembly and the watch case.
    • Use the opening tool to pry up the back cover assembly of your Huawei Watch GT 2 (42 mm).
    • Don't fully remove the back cover assembly just yet. It's still connected to the motherboard.
  4. How to Open the Huawei Watch GT 2 (42 mm), Lift the back cover assembly: passo 4, imagem 1 %32 How to Open the Huawei Watch GT 2 (42 mm), Lift the back cover assembly: passo 4, imagem 2 %32
    • Carefully swing the back cover assembly open to an upward position.
Conclusão
To reassemble your Huawei Watch GT 2 (42 mm), follow these instructions in reverse order.
Opening didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for troubleshooting help.
Adriana Zwink
Membro desde: 12/18/19
48.729 Reputação
Autoria de 167 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.410 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 27
Últimos 30 dias: 98
Duração total: 3,088
