Ir para o conteúdo principal
How to Lubricate a Zipper
O que você precisa
  1. How to Lubricate a Zipper, How to Lubricate a Zipper: passo 1, imagem 1 %32 How to Lubricate a Zipper, How to Lubricate a Zipper: passo 1, imagem 2 %32 How to Lubricate a Zipper, How to Lubricate a Zipper: passo 1, imagem 3 %32
    • Lay your garment on a table.
    • If you can, unzip the zipper.
    • If you can't move the slider, just work around it.
    • Using the brush located on top of the Zip Care bottle, or simply using a nylon brush, work the dirt and debris off of the zipper coil or the teeth of the zipper.
    Pergunte ao FixBot
    Comentar
  2. How to Lubricate a Zipper: passo 2, imagem 1 %32 How to Lubricate a Zipper: passo 2, imagem 2 %32
    • Pinch the slider in your fingers, so that you can see into the area where the coil rests.
    • Use the brush to free any dirt or debris caught inside the slider.
    Pergunte ao FixBot
    Comentar
  3. How to Lubricate a Zipper: passo 3, imagem 1 %32 How to Lubricate a Zipper: passo 3, imagem 2 %32 How to Lubricate a Zipper: passo 3, imagem 3 %32
    • Place a paper towel behind the zipper.
    • To prevent messes, make sure that the paper towel is touching the underside of the teeth or coil.
    Pergunte ao FixBot
    Comentar
  4. How to Lubricate a Zipper: passo 4, imagem 1 %32 How to Lubricate a Zipper: passo 4, imagem 2 %32 How to Lubricate a Zipper: passo 4, imagem 3 %32
    • Twist open the Zip Care.
    • Gently squeeze the bottle as you slide the brush along the teeth or coil of the zipper to apply the lubricant.
    • Repeat this on both sides of the zipper teeth or coil.
    Pergunte ao FixBot
    Comentar
  5. How to Lubricate a Zipper: passo 5, imagem 1 %32 How to Lubricate a Zipper: passo 5, imagem 2 %32
    • Fold the paper towel over and dab any excess lubricant off the zipper.
    Pergunte ao FixBot
    Comentar
  6. How to Lubricate a Zipper: passo 6, imagem 1 %32 How to Lubricate a Zipper: passo 6, imagem 2 %32
    • Zip and unzip the zipper a few times to work the lubricant in between the teeth or coil.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
6 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
90.963 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 28.236 guias
1Comentário do guia
Hi Brittany, I’m hoping you have an answer for my favourite purse. The zipper is frozen due to the remnant of a plastic bag I put in my purse. Please advise!
Clair - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 45
Últimos 30 dias: 232
Ao todo: 122,193
