Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate the two grey latches on each side of the hood near the headlights.
Pull the latches away from the hood to release the latches.
Reach underneath the hood and push up on the lever located in the front center of the hood. You can now open the hood.
Prop the hood open by inserting the hood support rod into the designated hole on the underside of the hood.
Park a second vehicle front-to-front within 10 feet of the Jeep. Open the hood.
Be sure to have everything in the Jeep switched to the OFF position, including AC, headlights, radio, etc. to avoid getting electrocuted.
Leave the other vehicle's engine running.
Bring out the booster cables. You must attach the cables in THIS order to the batteries of both vehicles:
1) Connect one red clamp to the positive battery terminal on the Jeep (it will be the red spot on the battery) (Picture 1)
2) Connect the other red clamp to the positive battery terminal on the other working vehicle (Picture 2).
3) Connect one black clamp to the negative battery terminal on the other working vehicle (the negative terminal will be black and next to the red, positive terminal) (Picture 2).
Leave the booster cables attached to both vehicles for approximately 10 minutes before attempting to start the Jeep. If it does not start right away, wait 30 seconds and try again. Continue to try until it starts, taking short breaks in between attempts.
Once the engine starts, let the Jeep run for about 5 minutes to recharge the battery.
In reverse order, remove the booster cables now that the Jeep is running and the battery has recharged.
3 outras pessoas executaram este guia.
2 comentários
Nice and easy. I wold prefer 2 gauge booster cables.
This particular is usually apparently essential and moreover outstanding truth along with for sure fair-minded and moreover admittedly useful My business is looking to find in advance designed for this specific useful stuffs… Digital Marketing Services
