Ir para o conteúdo principal
How to Install and Remove Tiles
O que você precisa
  1. How to Install and Remove Tiles, Remove the Front Panel: passo 1, imagem 1 %32 How to Install and Remove Tiles, Remove the Front Panel: passo 1, imagem 2 %32 How to Install and Remove Tiles, Remove the Front Panel: passo 1, imagem 3 %32
    • Use your fingers to pull the Front Panel off the magnets securing it to the chassis.
    Pergunte ao FixBot
    Comentar
  2. How to Install and Remove Tiles, Remove the Tiles: passo 2, imagem 1 %32 How to Install and Remove Tiles, Remove the Tiles: passo 2, imagem 2 %32 How to Install and Remove Tiles, Remove the Tiles: passo 2, imagem 3 %32
    • Use your fingers to push the bottom of the Tile up and off the front panel and release its clips.
    • Remove the Tile.
    Pergunte ao FixBot
    Comentar
  3. How to Install and Remove Tiles: passo 3, imagem 1 %32 How to Install and Remove Tiles: passo 3, imagem 2 %32 How to Install and Remove Tiles: passo 3, imagem 3 %32
    • Repeat this procedure for the remaining tiles.
    Pergunte ao FixBot
    Comentar
  4. How to Install and Remove Tiles, Install the Tiles: passo 4, imagem 1 %32 How to Install and Remove Tiles, Install the Tiles: passo 4, imagem 2 %32 How to Install and Remove Tiles, Install the Tiles: passo 4, imagem 3 %32
    • Tiles can be installed in any orientation, even the ones with graphics.
    • Lay a Tile over an open slot on your Front Panel.
    • Use your fingers to press the tile into the slot and engage the clips.
    • You'll hear and feel an audible "click" when the clips engage.
    Pergunte ao FixBot
    Comentar
  5. How to Install and Remove Tiles: passo 5, imagem 1 %32 How to Install and Remove Tiles: passo 5, imagem 2 %32 How to Install and Remove Tiles: passo 5, imagem 3 %32
    • Install the remaining Tiles.
    Pergunte ao FixBot
    Comentar
  6. How to Install and Remove Tiles: passo 6, imagem 1 %32 How to Install and Remove Tiles: passo 6, imagem 2 %32 How to Install and Remove Tiles: passo 6, imagem 3 %32
    • Lay the bottom of the Front Panel on the small, protruding lip in the silver base to align its tabs.
    • Press the Front Panel flat to the chassis and let it align to the magnets.
    Pergunte ao FixBot
    Comentar
Conclusão
If you need help, contact Framework support.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
241.504 Reputação
Autoria de 1.180 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 12
Últimos 30 dias: 40
Ao todo: 370
