Ir para o conteúdo principal
How to Install an HID Conversion Kit
O que você precisa
    1. How to Install an HID Conversion Kit, Headlights: passo 1, imagem 1 %32 How to Install an HID Conversion Kit, Headlights: passo 1, imagem 2 %32
      • Open the hood.
      • Locate the back of the headlights and remove the bolts holding the headlight housing.
      Pergunte ao FixBot
      Comentar
    2. How to Install an HID Conversion Kit: passo 2, imagem 1 %32
      • Unplug the stock harness and remove the headlights.
      Pergunte ao FixBot
      Comentar
    3. How to Install an HID Conversion Kit: passo 3, imagem 1 %32 How to Install an HID Conversion Kit: passo 3, imagem 2 %32
      • Remove battery negative terminal.
      • Remove headlight cover and remove factory halogen bulb.
      Pergunte ao FixBot
      Comentar
    4. How to Install an HID Conversion Kit: passo 4, imagem 1 %32
      • Take out the HID bulb from the plastic shell and remove the circular plastic piece.
      • Remember not to touch the HID bulb glass!
      • If you accidentally touch it, you can clean it with some rubbing alcohol.
      Pergunte ao FixBot
      Comentar
    5. How to Install an HID Conversion Kit: passo 5, imagem 1 %32 How to Install an HID Conversion Kit: passo 5, imagem 2 %32
      • Screw in the HID bulb back into the headlight housing.
      • Connect the wires of the HID bulb to the ballast and then connect the HID ballast back to the stock harness.
      Pergunte ao FixBot
      Comentar
    6. How to Install an HID Conversion Kit: passo 6, imagem 1 %32
      • Before you mount the ballast, test the HID light to make sure it lights up.
      • If not, turn the adapter wire 180 degrees.
      • Mount the HID ballast with zip ties.
      Pergunte ao FixBot
      Comentar
    7. How to Install an HID Conversion Kit: passo 7, imagem 1 %32 How to Install an HID Conversion Kit: passo 7, imagem 2 %32 How to Install an HID Conversion Kit: passo 7, imagem 3 %32
      • Put everything (like the headlight housing) back.
      • Enjoy!
      Pergunte ao FixBot
      Comentar
Conclusão
Enjoy your new HID Conversion Kit and upgraded headlights or fog lights.
7 outras pessoas executaram este guia.
Eric Wu
Membro desde: 01/21/15
3.600 Reputação
Autoria de 23 guias
1Comentário do guia
Tradução em português sff.
Dall Costa - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 53
Últimos 30 dias: 222
Ao todo: 21,393
