Ir para o conteúdo principal
How to Install a 2.5" SSD Into a Silicone Enclosure
  1. How to Install a 2.5" SSD Into a Silicone Enclosure, Insert the SSD into the enclosure: passo 1, imagem 1 %32 How to Install a 2.5" SSD Into a Silicone Enclosure, Insert the SSD into the enclosure: passo 1, imagem 2 %32
    • Before you insert the new hard drive, note the orientation of the SATA connectors embedded in the enclosure:
    • The wide power SATA port
    • The narrower data SATA port
  2. How to Install a 2.5" SSD Into a Silicone Enclosure: passo 2, imagem 1 %32 How to Install a 2.5" SSD Into a Silicone Enclosure: passo 2, imagem 2 %32 How to Install a 2.5" SSD Into a Silicone Enclosure: passo 2, imagem 3 %32
    • Using the previous step, orient the new drive so that its SATA connectors will align with the enclosure's.
    • Slide the drive into the enclosure's opening.
    • Push the drive into the enclosure until it stops sliding and the SATA connectors are completely seated.
  3. How to Install a 2.5" SSD Into a Silicone Enclosure: passo 3, imagem 1 %32 How to Install a 2.5" SSD Into a Silicone Enclosure: passo 3, imagem 2 %32 How to Install a 2.5" SSD Into a Silicone Enclosure: passo 3, imagem 3 %32
    • Stretch the remaining enclosure corners over the drive so that the silicone cover encapsulates the drive.
Conclusão
Your drive is ready to be used!
3 outras pessoas executaram este guia.
Arthur Shi
Membro desde: 01/03/18
309.324 Reputação
Autoria de 699 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.583 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 31
Ao todo: 1,976
