Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use the included screwdriver to remove the two Phillips screws.
Slide the plastic tray out of the aluminum housing.
Set the drive in the plastic tray and align the drive ports with the tray socket.
Carefully push the drive into the tray socket to seat the ports.
Press the drive's raised edge down into the plastic tray.
Flip the drive tray over.
Use the a Phillips screwdriver to install the four mounting screws (included in the kit) to secure the drive to the tray.
Slide the tray back into the aluminum housing.
Reinstall the two Phillips screws to secure the tray.
48 outras pessoas executaram este guia.
8 comentários
Now what do I do?
You will need to plug the enclosure into a computer to access it. From there, you can format the drive or retrieve data.
How do I plug the enclosure into a computer? Are there cables? Thank you.
Very good explanation on "How to do it yourself"
Very good Instructions with clear explanations.
