Introdução
This guide shows how to install a 2.5-inch hard drive into the aluminum enclosure sold by iFixit. The enclosure can hold either a SSD or a standard 2.5-inch (platter) hard drive, as long as they have the proper SATA connectors.
If you have a silicone enclosure, follow this guide instead.
O que você precisa
Set the drive in the plastic tray and align the drive ports with the tray socket.
Carefully push the drive into the tray socket to seat the ports.
Press the drive's raised edge down into the plastic tray.
Your drive is ready for use!
52 outras pessoas executaram este guia.
10 comentários
Now what do I do?
You will need to plug the enclosure into a computer to access it. From there, you can format the drive or retrieve data.
How do I plug the enclosure into a computer? Are there cables? Thank you.
Very good explanation on "How to do it yourself"
Very good Instructions with clear explanations.
