Ir para o conteúdo principal
How to Hem Pants by Hand-Sewing
O que você precisa
  1. How to Hem Pants by Hand-Sewing, How to Hem Pants by Hand-Sewing: passo 1, imagem 1 %32
    • Wear the pants and fold the hem up until you get your desired length.
  2. How to Hem Pants by Hand-Sewing: passo 2, imagem 1 %32
    • Remove the pants, making sure that the folded hem remains fixed.
    • Lay the pants down on a table and measure the length from the original hem to the folded edge.
    • Make sure to take note of all of your measurements.
  3. How to Hem Pants by Hand-Sewing: passo 3, imagem 1 %32
    • Turn the pants inside out, and unfold the folded edge.
    • Starting from the original hem, measure out the length of what will be your new hem.
    • The length you will need for this step would be the length you measured out from the previous step.
    • Using your fabric marker, draw a line marking where your new hem would be.
  4. How to Hem Pants by Hand-Sewing: passo 4, imagem 1 %32
    • Starting from the line you just created, measure out 1 inch and mark with a line.
  5. How to Hem Pants by Hand-Sewing: passo 5, imagem 1 %32
    • Using the 1 inch line as your guide, cut off the extra fabric.
  6. How to Hem Pants by Hand-Sewing: passo 6, imagem 1 %32 How to Hem Pants by Hand-Sewing: passo 6, imagem 2 %32
    • Fold the raw edge up to the new hem line.
    • Fold it again along the new hem line, so that the raw edge is now inside the fold.
  7. How to Hem Pants by Hand-Sewing: passo 7, imagem 1 %32 How to Hem Pants by Hand-Sewing: passo 7, imagem 2 %32
    • Place a sewing pin parallel to the fold to make sure that the fold stays in place.
    • Fold and pin all the way around to create your new hem.
  8. How to Hem Pants by Hand-Sewing: passo 8, imagem 1 %32
    • Have your needle threaded and ready to go.
    • Sew the fold close to create a new hem; try to keep your stitches small and even.
    • White thread was used instead of black to make the stitches more evident in the pictures.
  9. How to Hem Pants by Hand-Sewing: passo 9, imagem 1 %32 How to Hem Pants by Hand-Sewing: passo 9, imagem 2 %32 How to Hem Pants by Hand-Sewing: passo 9, imagem 3 %32
    • Once you're done stitching, tie off the thread by creating a knot towards the end of the string.
    • Cut off the excess string above the knot.
    • Remove all of the sewing pins.
    • Repeat steps 3 to 8 for the other pant leg using the same measurements, and then you're officially done!
Conclusão
19 outras pessoas executaram este guia.
Irish Pellas
Membro desde: 09/29/15
736 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 15-5, Green Fall 2015 Membro de Cal Poly, Team 15-5, Green Fall 2015
CPSU-GREEN-F15S15G5
4 Membros
Autoria de 14 guias
2 comentários
Thank you for this guide! The only thing I am uncertain about is how determine a good length for the pants. I read in another guide that it would be good to measure with shoes on. So that the pant leg grazes the shoe. Can you recommend the same?
Christin Kalina - Responder
Vielen lieben Dank für diese ausführliche Anleitung.
Die Beschreibung ist sehr gut erklärt und anhand der Fotos kann man sich ein besseres Bild davon machen.
Meine Jeans hat nun die richtige Länge und ich bin sehr stolz auf mein Meisterwerk. :)
Jessica Schütze - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 15
Últimos 7 dias: 112
Últimos 30 dias: 536
Ao todo: 147,991
