Ir para o conteúdo principal
How to Fix the Worx Pegasus Workbench lower tray
O que você precisa
  1. How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: passo 1, imagem 1 %32 How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: passo 1, imagem 2 %32
    • If yours became detached, make sure you manually re-assemble the tray as it is supposed to be
  2. How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: passo 2, imagem 1 %32 How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: passo 2, imagem 2 %32
    • Drill a small hole, the smallest possible but large enough to allow a zip tie to go through. I used a 1.5mm drill bit.
  3. How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: passo 3, imagem 1 %32 How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: passo 3, imagem 2 %32
    • Route a Zip Tie through the hole you just drilled and around the hinge barrel.
    • Cut the excess with scissors or wire cutters.
    • Do this procedure at least on two hinges: the leftmost and rightmost. For best results, address all six hinges.
  4. How to Fix the Worx Pegasus Workbench lower tray, Enjoy your reliable workbench: passo 4, imagem 1 %32
    • If done correctly, the tray is not going to fail again.
    • This fix also adds a little bit more strength to the lower tray.
    • Enjoy!
Linha de Chegada
Uma outra pessoa concluiu este guia.
RodCastler
Membro desde: 10/29/22
109 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 22
Duração total: 155
