Ir para o conteúdo principal
How to Fix the Worx Pegasus Workbench lower tray
O que você precisa
  1. How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: passo 1, imagem 1 %32 How to Fix the Worx Pegasus Workbench lower tray, Re-assemble per factory: passo 1, imagem 2 %32
    • If yours became detached, make sure you begin by manually re-assembling the tray as it came from factory.
  2. How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: passo 2, imagem 1 %32 How to Fix the Worx Pegasus Workbench lower tray, Drill through the hinge: passo 2, imagem 2 %32
    • Drill a small hole, the smallest possible but large enough to allow a zip tie to go through. I used a 1.5mm drill bit.
  3. How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: passo 3, imagem 1 %32 How to Fix the Worx Pegasus Workbench lower tray, Route a Zip Tie: passo 3, imagem 2 %32
    • Route a Zip Tie through the hole you just drilled and around the hinge barrel.
    • Cut the excess with scissors or wire cutters.
    • Do this procedure at least on two hinges: the leftmost and rightmost. For best results, address all six hinges.
  4. How to Fix the Worx Pegasus Workbench lower tray, Enjoy your reliable workbench: passo 4, imagem 1 %32
    • If done correctly, the tray is not going to fail again.
    • This fix also adds a little bit more strength to the lower tray.
    • Enjoy!
Linha de Chegada
Uma outra pessoa concluiu este guia.
RodCastler
Membro desde: 10/29/22
403 Reputação
Autoria de 2 guias
2Comentários do guia
Nice job. Only critique is a better or close up of where you drill the holes for the zip ties. Hard to see from your pics. I figured it out and added all 6 to my hinges as that tray falls off non-stop. Thanks! I also added 4 other zip ties to the 4 small exterior holes on the outside of the tray that lock the perimeter attachment hinges into place as well.
Ray Wright - Responder
It wood be good to have some instructions on fitting and securing the outer hinges of the bottom tray
Tony Johnson - Responder
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 19
Últimos 30 dias: 42
Ao todo: 760
