Ir para o conteúdo principal
How to Fix a Sticking Deadbolt
O que você precisa
  1. How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: passo 1, imagem 1 %32 How to Fix a Sticking Deadbolt, How to Fix a Sticking Deadbolt: passo 1, imagem 2 %32
    • Use a Phillips screwdriver to remove both of the ¾-inch screws from the strike plate.
  2. How to Fix a Sticking Deadbolt: passo 2, imagem 1 %32 How to Fix a Sticking Deadbolt: passo 2, imagem 2 %32
    • Remove both of the 2.5 inch mounting screws from the lock cylinder.
  3. How to Fix a Sticking Deadbolt: passo 3, imagem 1 %32
    • After all four screws have been taken out, slide the latch of the deadbolt out of the door frame.
  4. How to Fix a Sticking Deadbolt: passo 4, imagem 1 %32 How to Fix a Sticking Deadbolt: passo 4, imagem 2 %32
    • Spray GumOut parts cleaner at an angle into the latch of the deadbolt.
    • Use a rag to clean and dry off latch.
    • We suggest using GumOut cleaning solutions, which is available at most home improvement stores.
  5. How to Fix a Sticking Deadbolt: passo 5, imagem 1 %32
    • Spray GumOut parts cleaner into the key cylinder to lubricate chamber.
  6. How to Fix a Sticking Deadbolt: passo 6, imagem 1 %32 How to Fix a Sticking Deadbolt: passo 6, imagem 2 %32
    • Insert dry powdered graphite into the key cylinder of the deadbolt.
    • Place the key into the cylinder to lubricate and clean the chamber.
    • If it is difficult to turn the key, then apply more dry powdered graphite into the cylinder.
  7. How to Fix a Sticking Deadbolt: passo 7, imagem 1 %32 How to Fix a Sticking Deadbolt: passo 7, imagem 2 %32
    • Apply the dry powdered graphite to the latch of the deadbolt.
    • Use a rag to remove excess dry powdered graphite from the latch.
  8. How to Fix a Sticking Deadbolt: passo 8, imagem 1 %32
    • Slide the latch of the deadbolt back into the door frame.
  9. How to Fix a Sticking Deadbolt: passo 9, imagem 1 %32 How to Fix a Sticking Deadbolt: passo 9, imagem 2 %32 How to Fix a Sticking Deadbolt: passo 9, imagem 3 %32
    • Take the lock cylinder and the 2.5 inch mounting screws and insert them through the latch of the deadbolt.
    • Then mount the key cylinder on the screws.
    • Use a Phillips screwdriver to tighten the 2.5 inch mounting screws and secure the deadbolt to the frame.
    • The cylinder should be mounted on the outside of the doorframe.
  10. How to Fix a Sticking Deadbolt: passo 10, imagem 1 %32
    • Use a Phillips screwdriver to screw in both of the ¾-inch screws back into the strike plate.
Conclusão
After following this fast fix guide, the sticking deadbolt should be fixed.
6 outras pessoas executaram este guia.
Equipe
Texas Tech, Team 22-5, Rauch Spring 2016 Membro de Texas Tech, Team 22-5, Rauch Spring 2016
TTU-RAUCH-S16S22G5
3 Membros
1 Guia de autoria
2Comentários do guia
GumOut Cleaner seems to be initially intended for Brakes and other auto parts. Is that the product you intend?
dan - Responder
Thank you! GumOut worked well. (I was amused to realize I already had it in my shed for cleaning my lawn mowers carburetor.) In my situation the deadbolt wouldn't fully retract with the key any more, but I could push it the rest of the way with my finger. After removing the latch in step 3, I could turn the latch with a flat head screwdriver and find the place where it "sticks." After cleaning the latch out with a few sprays of GumOut and exercising it with a flat head screwdriver, the latch was working smoothly again. Thank you for the helpful guide!
Russ Williston - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 29
Últimos 30 dias: 96
Ao todo: 40,719
