Ir para o conteúdo principal
How to Fix a Mirror Frame
O que você precisa
  1. How to Fix a Mirror Frame, How to Fix a Mirror Frame: passo 1, imagem 1 %32
    • Gather all your broken frame pieces and gently clean off any dust or debris. Once the pieces are clean, arrange them to determine how they fit back into the damaged section. This will help you understand the order in which they need to be glued.
    Pergunte ao FixBot
    Comentar
  2. How to Fix a Mirror Frame: passo 2, imagem 1 %32
    • Once the pieces are arranged, apply a small amount of Gorilla Glue to the edges that need to be reattached. Press each piece firmly into place. Work slowly to make sure each section aligns with the original shape of the frame.
    • Caution: Gorilla Glue expands as it dries. Use sparingly to prevent overflow onto the visible surface.
    Pergunte ao FixBot
    Comentar
  3. How to Fix a Mirror Frame: passo 3, imagem 1 %32
    • Use tension bands (rubber bands or elastic straps) to hold the pieces tightly together while the glue cures. Place the bands so that they apply gentle, even pressure across the repaired area without pressing against the mirror glass. Let the glue dry according to the instructions on the adhesive bottle.
    Pergunte ao FixBot
    Comentar
  4. How to Fix a Mirror Frame: passo 4, imagem 1 %32 How to Fix a Mirror Frame: passo 4, imagem 2 %32
    • Once the glue is fully dry, check for any gaps or visible seams between the pieces. Use clay or wood filler to fill in the gaps to create a smooth, continuous surface. Shape the filler to match the pattern and curves of the existing frame. Allow the filler to dry completely before moving on.
    Pergunte ao FixBot
    Comentar
  5. How to Fix a Mirror Frame: passo 5, imagem 1 %32 How to Fix a Mirror Frame: passo 5, imagem 2 %32
    • After the filler has dried, mix your paint to match the color and finish of the frame. Use a small brush or sponge to apply the paint to the repaired areas. Blend it carefully so it matches the rest of the frame. Allow the paint to dry fully before handling.
    Pergunte ao FixBot
    Comentar
  6. How to Fix a Mirror Frame: passo 6, imagem 1 %32
    • Let the repaired mirror frame dry for 24 hours. Once everything is set, your mirror should be fully restored and ready to use again.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 107
Ao todo: 774
