Introdução
The soldered connections in the average XLR cable can break under heavy use. Use this guide to disassemble an XLR connector and resolder the broken connection.
O que você precisa
Place the end of the XLR Cable on a clean, uncluttered surface.
Using a small screwdriver, unscrew the single screw near the top of the cable.
Gently pull apart the exterior metal from the internal mechanism.
4 outras pessoas executaram este guia.
Um comentário
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
