Ir para o conteúdo principal
How to Fix a Broken XLR Microphone Cable
O que você precisa
  1. How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: passo 1, imagem 1 %32 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: passo 1, imagem 2 %32 How to Fix a Broken XLR Microphone Cable, How to Fix a Broken XLR Microphone Cable: passo 1, imagem 3 %32
    • This guide will utilize a soldering iron. Please use a heat-resistant surface and proceed with caution.
    • Place the end of the XLR Cable on a clean, uncluttered surface.
    • Using a small screwdriver, unscrew the single screw near the top of the cable.
    • Gently pull apart the exterior metal from the internal mechanism.
  2. How to Fix a Broken XLR Microphone Cable: passo 2, imagem 1 %32
    • Assess which connections have fallen loose. In this instance, the white cable is disconnected.
  3. How to Fix a Broken XLR Microphone Cable: passo 3, imagem 1 %32 How to Fix a Broken XLR Microphone Cable: passo 3, imagem 2 %32
    • Assess whether or not there's enough exposed wire to reconnect loose cables. In this instance, the exposed cables are too short to effectively reconnect.
    • If the exposed wires are too short, use wire strippers or a razor to cut back the insulation.
    • Separate the wires.
  4. How to Fix a Broken XLR Microphone Cable: passo 4, imagem 1 %32 How to Fix a Broken XLR Microphone Cable: passo 4, imagem 2 %32 How to Fix a Broken XLR Microphone Cable: passo 4, imagem 3 %32
    • Soldering irons are extremely hot. Proceed with extreme caution.
    • Solder each of the loose wires to the coinciding metal prong.
    • For more information on effectively soldering wire, please visit iFixit's Soldering Guide.
    • If necessary, use a thin wire to further manipulate the connection.
  5. How to Fix a Broken XLR Microphone Cable: passo 5, imagem 1 %32 How to Fix a Broken XLR Microphone Cable: passo 5, imagem 2 %32
    • When the soldering is complete, reconnect the metal exterior to the head of the cable.
    • Using a small screwdriver, reattach the single screw.
Conclusão
4 outras pessoas executaram este guia.
Abbie Zajac
Membro desde: 01/19/16
203 Reputação
Autoria de 1 guia
Equipe
Um comentário
Great repair. If the cabke is broken I have a video on resolving that issue. https://youtu.be/E8CiX4cnc-U
DIM Tips - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 105
Duração total: 25,212
