Ir para o conteúdo principal
How to Fix Stuck Yamaha PSR-6 Keyboard Keys
O que você precisa
  1. How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 1, imagem 1 %32 How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 1, imagem 2 %32 How to Fix Stuck Yamaha PSR-6 Keyboard Keys, How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 1, imagem 3 %32
    • Turn around the keyboard with the keys facing down.
    • Remove the 15 10 mm screws using a Phillips #1 screwdriver.
    • Remove the five 12 mm screws using a Phillips #1 screwdriver.
    • Remove the extra two 10 mm screws in the bottom using a Phillips #1 screwdriver.
  2. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 2, imagem 1 %32
    • Pull the tab and remove the battery cover.
  3. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 3, imagem 1 %32
    • Take the back plate of the piano with both hands and remove it.
  4. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 4, imagem 1 %32 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 4, imagem 2 %32
    • Turn around the piano with the tiles facing up.
    • Remove the speaker's cover on the left side of the keyboard.
    • Remove the plastic cover on the right side of the keyboard.
  5. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 5, imagem 1 %32 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 5, imagem 2 %32
    • Flip the keyboard with the keys facing down.
    • Remove the single 12 mm screw using a Phillips #1 screwdriver.
  6. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 6, imagem 1 %32
    • Lift the front plate of the keyboard and rotate it 180°.
    • While doing this, grab the speaker with the other hand so it doesn't fall and hit the table.
  7. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 7, imagem 1 %32 How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 7, imagem 2 %32
    • Remove all the 10 mm screws on the top of the keys using a Phillips #1 screwdriver.
  8. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 8, imagem 1 %32
    • Use a spudger to separate the teeth to the plates that hold the keys together.
    • Do this gently as the plate may be fragile.
  9. How to Fix Stuck Yamaha PSR-6 Keyboard Keys: passo 9, imagem 1 %32
    • Pull the black plate that holds the keys together horizontally away from the keys.
    • With the top of the keys exposed, use a damp cloth or wipes to clean the space between the tiles.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 13
Últimos 30 dias: 52
Duração total: 1,863
