Ir para o conteúdo principal
How to Fix Stick Drift for a PlayStation Dualsense Controller V1
O que você precisa
  1. How to Fix Stick Drift for a PlayStation Dualsense Controller V1, How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 1, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1, How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 1, imagem 2 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1, How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 1, imagem 3 %32
    • Insert an opening tool into the bottom right corner of the controller.
    • Lift upwards with the opening tool.
    • Continue using the opening tool to pry up the inner sides of the black rim.
    • Repeat on the opposite side.
  2. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 2, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 2, imagem 2 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 2, imagem 3 %32
    • Lift the black cover upwards to remove.
  3. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 3, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 3, imagem 2 %32
    • Insert the opening tool below the L1 button and pry the button away from the controller.
  4. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 4, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 4, imagem 2 %32
    • Insert the opening tool below the R1 button and pry the button away from the controller.
  5. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 5, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 5, imagem 2 %32
    • Detach the two middle clips using the opening tool or your fingers.
  6. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 6, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 6, imagem 2 %32
    • Remove the top right and left 6.4 mm screws using a Phillips #00 screwdriver.
  7. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 7, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 7, imagem 2 %32
    • Remove the bottom right and left 6.4 mm screws using a Phillips #00 screwdriver.
  8. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 8, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 8, imagem 2 %32
    • Insert the opening tool in between the sides to open the case.
  9. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 9, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 9, imagem 2 %32
    • With both hands, pull apart the white bottom case to remove.
  10. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 10, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 10, imagem 2 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 10, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using a pair of tweezers or your fingers, disconnect the battery from the motherboard.
  11. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 11, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 11, imagem 2 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 11, imagem 3 %32
    • Use tweezers or your fingers to pull the orange ribbon.
    • Remove the 6.4 mm screw using a Phillips #00 screwdriver.
    • Lift the battery bracket.
  12. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 12, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 12, imagem 2 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 12, imagem 3 %32
    • Use tweezers or your fingers to detach the four ribbons from the motherboard.
  13. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 13, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 13, imagem 2 %32
    • Guide the joysticks through the front case and lift the motherboard.
  14. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 14, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 14, imagem 2 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 14, imagem 3 %32
    • Remove the joystick covers by pulling straight off.
  15. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 15, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 15, imagem 2 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 15, imagem 3 %32
    • Use the opening tool to snap open the green tabs.
  16. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 16, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 16, imagem 2 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 16, imagem 3 %32
    • Use tweezers to remove the wiper disks.
  17. How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 17, imagem 1 %32 How to Fix Stick Drift for a PlayStation Dualsense Controller V1: passo 17, imagem 2 %32
    • Using a cotton tip with 99.8% isopropyl alcohol, clean around the black rims of the green tabs and the wiper disks.
Conclusão
70 outras pessoas executaram este guia.
Yadsari
Membro desde: 11/01/23
2.074 Reputação
Autoria de 1 guia
Equipe
16Comentários do guia
Just cleaning the carbon track on the potentiometer is not really a long term fix for stick drift. Better fixes would be to either replace the photometers or to replace the complete stick with a hall-effect joy stick.
David Fear - Responder
Do you have a link?
Nora -
I did it, sadly cleaning wasn't enough. So I guess I'll have to replace something.
Riedweg Guillaume - Responder
There is now a real fix for this, hall effect mod by Jun Zheng. About $25 per pair of mods. Check out the guys YouTube, link to his AliExpress store in his video description. Just use the guide here for disassembly. https://youtube.com/@junZeng-520?si=UYbf...
Alex Lao - Responder
Upon reassembly I get the three orange blinks error. Research says there’s a ribbon connection error, is that right? I went through steps again and checked all connections, but no change. Have I short circuited something? Would replacing the potentiometer even fix it at this point? Have I damaged a ribbon? (There is no visible damage).
joe lewis - Responder
Comentar
Visualizações:
Últimas 24 horas: 120
Últimos 7 dias: 846
Últimos 30 dias: 3,473
Ao todo: 84,444
