Ir para o conteúdo principal
How to Fix Logitech G403 Double Click Issue
O que você precisa
  1. How to Fix Logitech G403 Double Click Issue, How to Fix Logitech G403 Double Click Issue: passo 1, imagem 1 %32
    • Use a prying tool or your hand to take out both sides of the mouse feet.
  2. How to Fix Logitech G403 Double Click Issue: passo 2, imagem 1 %32
    • Use a precision screwdriver to remove four screws from the mouse.
  3. How to Fix Logitech G403 Double Click Issue: passo 3, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 3, imagem 2 %32
    • Slowly open the mouse, and take care not to tear the ribbon cable.
    • Detach the cable connector.
  4. How to Fix Logitech G403 Double Click Issue: passo 4, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 4, imagem 2 %32
    • Remove seven screws from the upper cover.
  5. How to Fix Logitech G403 Double Click Issue: passo 5, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 5, imagem 2 %32
    • Remove four screws from the mouse.
    • Remove the mouse click cover.
  6. How to Fix Logitech G403 Double Click Issue: passo 6, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 6, imagem 2 %32
    • Remove the five screws attached to the mouse click switches.
  7. How to Fix Logitech G403 Double Click Issue: passo 7, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 7, imagem 2 %32
    • Open the mouse switch using a prying tool or your hands.
    • Be careful not to lose the white plastic part from the mouse switch.
  8. How to Fix Logitech G403 Double Click Issue: passo 8, imagem 1 %32 How to Fix Logitech G403 Double Click Issue: passo 8, imagem 2 %32
    • Find the place where more tension is needed.
    • Use a prying tool or your hand to give more tension to the copper piece, making sure the copper is curved.
Conclusão
10 outras pessoas executaram este guia.
Jisuk Kang
Membro desde: 07/05/20
415 Reputação
Autoria de 1 guia
Equipe
10Comentários do guia
step 8 made no sense and had to google it
rel - Responder
did you find a video about that? if you could send it pls or if it was some place where talk more about it
Lian López -
Worked!!! I had this problem for years, even stoped playing valorant bacause of that. Thanks
VampireKing - Responder
I could not open these screws :( What are the screwdriver size to open these?
Siim - Responder
Comentar
Visualizações:
Últimas 24 horas: 16
Últimos 7 dias: 75
Últimos 30 dias: 300
Ao todo: 35,698
